Old 02-06-2011, 11:08 AM
Derek Miller's Avatar
Derek Miller Derek Miller is offline
Default Need Pics of 18x11 with 335/30R18 mounted tires
Does anybody have pictures or a link to pictures with 18x11 wheels mounted with 335/30R18 tires (preferably on a 67 or 68 Camaro). I really like the BFGoodrich KDW tires and their price compared to the Michelins is much better. I was looking at running 17in wheels but would be forced to use the Michelins. Some of the rims I plan on running only seem to come as large as 18x11 or 17x11. I know you can have them widened but don't really want to go down that road if I can avoid it. The 335s say they can be mounted on a 11in wheel but I would like to see how much bulge they have when done.
Thanks,
"Anything Worth Doing, Is Worth Overdoing."
Old 02-11-2011, 10:35 AM
Correct me if I am wrong, but isn't Velocity, the 1968 camaro built by Air Ride using a 18x11 CCW rear wheel with 335/30R18 BFGs. I always thought they were 18x12 but I came across a few articles and even their own website says that they used 18x11 rear wheels. The bulge does not look that bad and even protects the wheel a little more.
Thanks,
Old 02-11-2011, 01:16 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
I have 18x11.5's that you can check out. Go to my build link in my signature.
Chris
Old 02-11-2011, 02:13 PM
awr68's Avatar
awr68 awr68 is offline
Like Chris, I'm have a 18x11.5 w/ 335 tire.
I had 17x10's w/ 315 and didn't care for the look (needed a wider wheel and the tire was too short).
Tony
'68 Camaro
Old 02-11-2011, 02:18 PM
I know some of the 17 inch wheels come in 17x11, but what 18 inch wheel is limited to 11 inches wide? Once you go over 10" wide, isn't it all custom anyway?
Old 02-12-2011, 05:26 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
18's, In a 2 piece, yeah.
3 piece are usually about the same in price.
Old 02-11-2011, 02:22 PM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
BFG recommends 11.5-12.5 rims with a 335 same with the PS2's. but Michelin makes a 315 and BFG doesn't. i think an 11" rim with a 335 would have too much tire bulge and look bad on that wide of tire.
what rims are you looking at? there are a lot of wheel manufactures that will make you 11.5 or wider wheels if you ask.
Old 02-11-2011, 05:45 PM
That is great, TireRack shows that you can go down to a 11in wheel with the 335 but when you go to the BFGoodrich website, they show that a 11.5" wheel is the minimum. Some of the wheels I have been looking at are the Vintage Wheel Works and they will only go up to a 11in wheel. I like the vintage look as I feel it won't go out of style. Not sure if I want to go with a 3 piece wheel, seems like it might be a pain to keep up the cleaning with all of the exposed fasteners unless you go with a hidden fastener option that only a few wheel manufactures are able to offer. If anybody has an opinion on cleaning the typical 3 piece wheel I would love to hear it.
