Old 02-13-2011, 05:43 AM
ShadowGrayGuy's Avatar
ShadowGrayGuy ShadowGrayGuy is offline
Default 70 Chevelle on 18" Wheels
Hey all,
Tried to do a poor-man's manual photoshop for my '70 Chevelle build. Car is completely apart now, so I "borrowed" a photo from Google of another Shadow Gray '70 Chevelle, printed it out with a picture of the Jarvis '68 Chevelle as close to scale as possible, and cut & pasted the wheel setup onto the '70 stocker photo.
What do you think? I know the front wheel scale is a hair off (smaller than real life), but I think we have a winner - now if only I can find out from Team III if the wheels will clear my 14" Baer Pro-Plus brakes that are soon to arrive.
Stock
Jarvis' 68 with 18X11 305/35 & 18X9.5 275/35
My proposal:
I know the image quality is crappy, but I don't have photoshop or the skills to clip the wheels & alter the stance of the car digitally.
Think these will work? In reality, I was thinking that I'll probably step back to a 18X10 305/40 on the rear (18X11 in a stock wheel house might be pushing it & I like a little more sidewall on my tire...)
Old 02-13-2011, 05:55 AM
XcYZ's Avatar
XcYZ XcYZ is offline
That looks awesome.
My LS7 69 Camaro
Old 02-13-2011, 07:28 AM
coolwelder62's Avatar
An 11inch wheel will work fine,Just Order a BFH when you place your wheel order.
Old 02-13-2011, 08:26 AM
I've got to replace the outer wheelhouses, but the inners are stock & staying in place. How much "work" is it to squeeze 18X11 305/40's in there without making it look like a hammer-hack job?
Old 02-13-2011, 09:30 AM
ChevelleNV's Avatar
ChevelleNV ChevelleNV is offline
If you get the correct backspacing you should not have to hammer it out, you will probably have to roll the fender lip only. I was talking to Frank at Prodigy customs last week about wheels and tires for my 72 Chevelle. he was telling me they had just finished a customers 70 in the shop and they were able to fit a 20x11 in the rear with a 305/30 tire without doing and modifications to the wheel well.
I would suggest you give frank a call and he can probably give you the offsets they used for that customers car.
Greg R.
LSX Concepts
Old 02-14-2011, 09:42 AM
buickfunnycar.com's Avatar
Problem to me is even @ 11" wide (12" actually from edge-to-edge),those wheels still have no dish to them.
I realize those are step-lipped.
My 18x10 rears by comparison:
www.buickfunnycar.com
Old 02-14-2011, 02:20 PM
Well, today I went and picked up the car from media blasting and it looks like WIDER wheels are definitely feasible, as the inner wheel houses turned out to be swiss cheese, along with the 1" of trunk floorpan nearest the wheelhouses (will post pics of the cancer when I download the pics). So my thought is this: install the new stock inner wheel houses inward 1-1.5" of their stock location (over the top of the frame at this point) and then weld in a strip between the inner & outer wheelhouses to give me some extra room. I've got a good bodyman/welder who said it would be no sweat to do this, as the inner wheelhouses need replacement anyway. 18X11 rims should fit with minimal issues then, right? Any idea on backspacing? I've read that 6.5" will cause the inside of the wheel/tire to hit the frame, and 5.5" BS seems to be recommended for 10" wide wheels, so will 18X11 with 6.0" BS be best in the rear? Tires - is a 305/40 or 315/35 best for a lightly lowered chevelle PT car?
As for the fronts, it looks like I should go 18X9.5, 5.5" BS with a 275/35 or 275/40 tire (I like a little more sidewall, but I realize it has to fit in with the size/sidewall ratio of the rear wheels, too.
What do you all think?
Rob
