Old 01-16-2006, 02:54 PM
rocketman's Avatar
Default c-3 vette guys
whats the widest tire you can run wit hout offset trailing arms.like a 295-35,or a 315-35
is there a lowering kit for one.
Old 01-17-2006, 02:11 PM
69MyWay's Avatar
69MyWay 69MyWay is offline
275 40 17 on a 9" rim is the real max you can squeeze without rubbing on the pre 78 models. You can go to a 315 on the newer ones but it is wise to relocate the parking brake cable on the stock trailing arm. You can lower the rear by installing longer rear spring bolts.
Old 01-17-2006, 03:25 PM
rocketman's Avatar
its on 69.was think about offset trailing arms and 295-35 or 315-35.and using a vette brakes suspension kit to lower it.sound good or not
Old 01-17-2006, 05:08 PM
69MyWay's Avatar
I am running the VB&P performance plus on my 69 and offset trailing arms. You can go with a 5" bs on a 18" or larger rim and you might squeeze a 10" rim on the back. THe stock bs is 4" so you would only be going an inch wider on the outside allowing room for the 295. The 315 would be tight on the 69 fender lip (the are not as wide as the newer ones).
Old 01-17-2006, 05:43 PM
rocketman's Avatar
dumb question who vb&p,i dont reconginze that intinals
Old 01-18-2006, 08:52 PM
Wilkinshc Wilkinshc is offline
Try this link
http://www.VBandP.com
they are Vette Brakes and Products. If your a member on the corvette action board they will give you a 10%. see here:
http://www.corvetteactioncenter.com/...ad.php?t=74427
hope this helps.
Chuck
Old 01-18-2006, 08:53 PM
Try this link
hope this helps.
Chuck
