Old 03-05-2011, 04:55 AM
tommycomfort's Avatar
tommycomfort tommycomfort is offline
Default 1967 Chevelle (GM A-body) CLUTCH and BRAKE PEDAL ASSEMBLY *** SOLD ***
SOLD
This is a clutch and brake pedal assembly for a 1967 Chevelle, El Camino, and Malibu. It may also fit other GM A-Bodies, but do some research first. This set has been totally disassembled, media blasted, primed with self etching primer and painted a combination of semi-gloss black and cast iron enamel to copy the bare steel and painted original parts. The bushings have been replaced with new reproduction ones and new GM pedal pads have been installed. It also has a new brake light switch. As you can see in the picture it has the brake rod included. $175.00 plus actual shipping.
Tom
317 502 7460
Tom Farrington
66 Chevelle hardtop (ours) http://www.pro-touring.com/showthrea...PT-build-(ours)
64 Chevelle 4-dr wagon (wife's) http://www.pro-touring.com/showthrea...HAUL-LONG-ROOF
The new shop build https://lateral-g.net/forums/showthread.php4?t=42857
Old 03-05-2011, 05:00 AM
Roberts68 Roberts68 is offline
Thumbs up Nice Work!
If it fit a 1st Gen F-Body I would be all over it.
GLWS and your other project.
