Old 06-19-2011, 05:48 PM
70rs's Avatar
70rs 70rs is offline
Default Front acc drive/stock sub frame
Not sure if this should go in the "engine" forum or "chassis" since it deals with both.
Can anyone tell me which (if any) of the factory front acc'y drives on a LS motor will fit a stock second gen subframe?
I have seen first gen frames cut for clearance but I am in the dark on second gen fitment.
Oh yeah, WITH A/C & PS.
Thanks for any info.
Eric
Old 06-19-2011, 06:38 PM
ma73z's Avatar
ma73z ma73z is offline
X2, I'm in the same boat.
Old 06-19-2011, 08:36 PM
Ron in SoCal's Avatar
I am fairly certain (although not 100% on 2nd Gens) you can use a Corvette acc drive which puts the PS and Alt up high. You may want a kwik bracket to relocate the AC up high as well.
I went this route. Google the part numbers listed and you'll find a diagram:
https://lateral-g.net/forums/showthread.php4?t=32088
Good luck Eric!
Ron in SoCal
69 Camaro in progress
Old 06-20-2011, 08:53 AM
kovert kovert is offline
i had no idea that the stock sub frame would not work with ls engines...
great even with a inch setback motormounts its a no go ??
www.sureshotcustoms.com
Old 06-20-2011, 08:59 AM
70rs's Avatar
No, the LS engine is no problem in a stock frame. But the accy drive with AC may or may not create a clearance issue depending on which drive set up is used.
What I want to know is which factory set up will bolt in without any problems. Or which components from different drives need to be combined to get the same end result.
I ask because I know that first gen stock frames have had problems clearing some front drives.
I am not up to speed on the different drive systems and second gens.
Eric
Old 06-20-2011, 09:00 AM
MoonMan's Avatar
MoonMan MoonMan is offline
Hi Eric -
You should be good with the Corvette accessories as mentioned and then use the Kwik bracket for the a/c.
Not the best pic but here's my '72 with a LS1
Old 06-20-2011, 12:00 PM
Bam!
http://www.pro-touring.com/showthrea...s-and-Brackets
Ron in SoCal
Old 06-20-2011, 04:55 PM
70rs's Avatar
Originally Posted by MoonMan View Post
Hi Eric -
Thanks guys! That is exactly what I needed to know.
Eric
Old 06-21-2011, 10:03 PM
70rs's Avatar
Good luck Eric!
Thanks Ron.
I noticed in reading the thread above that the VA kit will not work with the stock GM ac compressor, and that I will need to buy the VA/Sanden compressor and the kwick bracket to make it all work with the LS2 front drive system?
So confusing.......lol!
Eric
Old 06-21-2011, 10:07 PM
Originally Posted by 70rs View Post
Thanks Ron.
That is correct Eric. And this is the easy part, just you wait...
Ron in SoCal
