Old 04-21-2012, 06:16 PM
FETorino's Avatar
FETorino FETorino is offline
Lightbulb T56 Magnum should I buy and where?
I keep doing more research and every trail seems to end with a close ratio T56 Magnum.
My car will have close to 700hp and over 600 ft lbs of torque I know that.
6200 rpm is the target for max hp.
My car will see some street miles including highway driving.
My car will be track oriented, I will drive it at both open track days and hopefully RTTC and other similar events.
Is there any other viable choice for a transmission?
Anyone have a preference on vendors. I was thinking of purchasing it thru LIberty. any reason to go elsewhere?
Rob in SoCal
Old 04-21-2012, 06:25 PM
Roberts68 Roberts68 is offline
Subscribed just to listen in. It seems everyone lists the trans at $2895 which I am sure is a Tremec MSRP rule. I am hoping to order very soon myself but I have a full auto to manual convesrion in front of me.
Old 04-21-2012, 06:43 PM
FETorino's Avatar
Well don't feel bad. My car may have been a 4 speed but other than the pedals that doesn't mean much. Bellhousing, driveshaft, clutch, crossmember are all different. With my new chassis I will likely be going to a hydraulic clutch set up to replace my z bar. Like I said I get to keep my left pedal from the 4 speed that's about it.
Rob in SoCal
Old 04-21-2012, 06:49 PM
Yep you're on it. Unless you want or can tolerate a dog box, you're lookin at a T56 Magnum. Sounds like the right fit for your needs.
I'm already looking forward to seeing your Torino at RTTC4.
Old 04-21-2012, 07:47 PM
The WidowMaker's Avatar
not only does tremec set the price, i couldnt get ANY dealer to budge. after some searching i found a 10% off coupon for summit and ordered from them. i was just after the tranny though since i already had everything from my tko. if that wasnt the case, i think i would have just gone with american powertrain.
"The WidowMaker"
Old 04-21-2012, 08:39 PM
badmatt's Avatar
badmatt badmatt is offline
MMR does sell for a bit cheaper than most.
Old 04-21-2012, 09:05 PM
FETorino's Avatar
Man I hope so. Still a long way to go to get there.
Rob in SoCal
