Old 05-28-2012, 09:51 AM
PhillySpeedNYC PhillySpeedNYC is offline
Default Hydraboost Groaning , will this ever go away?
I just had a kit installed on my Mustang and the brakes work great but the steering makes a groaning sound and i get some minor pedal kickback
the shop went through all the steps to bleed the air from the system and i do not see any air bubbles in the pump reservoir>
now i just got home and pulled the cap and saw a bunch of air bubbles that broke clear in 2-3 minutes. it seems to show air bubbles every other time i drive the car.
i keep turning the steering left to right and no real help
does it take some time to really get all the air out?
i only have 10 miles on the kit so far and i am super happy how it stops i just want to solve this groaning noise.
Old 05-28-2012, 10:02 AM
Drive it
Old 05-28-2012, 01:17 PM
FETorino's Avatar
FETorino FETorino is offline
I put a Hydroboost in my Wife's 75 Bronco.
Here are the bleeding steps I used when I set it up.
http://www.agrperformance.com/AGR-In...structions.pdf
It shouldn't groan. What pump are you using is it up for the task of big tires and hydro?
Let it sit a little and double check you don't have any small leaks. Start by discharging the hydro with three pedal depressions. Cycle the steering S L O W L Y a few times and recheck the reservoir level.
Rob in SoCal
Old 05-28-2012, 02:54 PM
When I first fired it up the return line fitting at the hydra boost unit leaked badly which I then fixed and now there are no more leaks. My car has a randals power rack and pinion which has a low volume high pressure GM pump with the black plastic fluid reservoir. It must be air still. I might try the steering wheel left and right circulation later and check. I leave my cap loose on my pump while I do this. Should I not? I just do not want to keep driving it risking burning up my pump or something
Old 05-28-2012, 04:14 PM
Musclerodz's Avatar
Do you have the return line T'd? What size reservoir do you have on it?
Mike Redpath
Musclerodz & Customz
facebook page
Old 05-28-2012, 06:34 PM
Yes its T in as the instructions suggested, not sure on the reservoir on this pump, its the same style pump all the rack and pinion guys are using.
