Old 06-27-2012, 10:16 PM
Jgpclone's Avatar
Jgpclone Jgpclone is offline
Default ford 9" for a 1969 camaro ?
i am about to pull the trigger on a dse ford 9" quadralink but my question is whats the narrowest i can go with a mini tub of corse and dose the OPTIONAL FORD 9" COMPLETE REAR AXLE come with the quadralink brackets i haven't had time to call at the moment busy at work working long hrs
thanx in advance
Hi my names is danny and im a "hp junky"
2006 tbss stock dd
1969 camaro project
2004 scsb silverado joe gibbs clone
Old 06-28-2012, 06:22 AM
ProPont ProPont is offline
Yes the brackets comes welded onto the ford 9" when you purchase the complete quadralink kit with housing. Here is some info I received from Dan Oddy about housing size and wheel back spacing. Maybe this will help you.
Thank you for using our Detroit Speed & Engineering products. On the 69 DSE Camaro we run a 18”x10” wide wheel with a 6.125” backspace and 275/35/R18 tire size. For the rear we run a 18”x12” wide wheel with a 6.125” backspace and a 335/30/R18 tire size however the rear axle has been narrowed to 56.000” from axle flange to axle flange. Currently we normally will run a 18”x12” wide wheel with a 5.500” backspacing and we will narrow the rear axle to 54.750” from axle flange to axle flange for a deeper dish wheel look. Let me know your axle length and I will be happy to help you with the correct backspacing for the rear wheels.
If you have any other questions please let me know.
Thanks.
Dan Oddy
Ph: 704-662-3272
Fax: 704-731-0989
Old 06-28-2012, 08:46 AM
Jgpclone's Avatar
kool thanx scoot
2006 tbss stock dd
1969 camaro project
Old 06-28-2012, 11:01 AM
Rybar's Avatar
Rybar Rybar is offline
I think mine is 54.5" wide and my 12" wheels have 5.375" BS.
Get your wheels first the way you want them, mick them up and then order the rear to fit.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 06-29-2012, 06:53 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
If you are planning to switch to a 9" you need to seriously consider a full floating hub rear. Moser sells a complete 9" rear minus the center section for $879 in any width you need. If you are not familiar with what a floating hub is do a search and you will find a good deal of information. I'm sure DSE has provisions for welding their brackets on your housing. Here's a pic of my Moser 9" floater.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 07-02-2012, 07:14 PM
Jgpclone's Avatar
Kool I'll look in too it,that rear end looks bad ass
2006 tbss stock dd
1969 camaro project
Old 07-02-2012, 07:10 PM
Jgpclone's Avatar
Thanx for the info I have the wheels but I'm Going To rehoop them I want like a 6" lip or more if I can but with a 12" rear tire
2006 tbss stock dd
1969 camaro project
