Old 07-18-2012, 03:45 PM
g356gear's Avatar
g356gear g356gear is offline
Default Fikse wheel face color change?
I have never taken apart a multi piece wheel before, but I was thinking of making a color change to the center section of my rims. I have tried to get in touch with Fikse but had no luck with anyone calling me back. Any advice or input on doing this? Thanks.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 07-18-2012, 05:09 PM
JMitch19's Avatar
JMitch19 JMitch19 is offline
Paul Van Nus painted the centers of his Fikses. I'm not sure what the process was, but you might want to get a hold of him at Dutchboy Restorations.
Jason Mitchell
1971 Camaro 416 LT1 Project
Old 07-19-2012, 10:39 AM
rjsjea's Avatar
rjsjea rjsjea is offline
I just did a set, followed this video from CCW. Used the torque specs from my wheel manufacturer. Best part is.....it worked the first time!!
http://www.ccwheel.com/incs/technica...air_video.html
RobS
71 Demon, AlterK - 4 link GenIII hemi conversion
66 Rambler Classic Wagon, LS conversion -Scott's IFS/4bar-bagged
Old 07-19-2012, 01:36 PM
Jano4's Avatar
Jano4 Jano4 is offline
I'm sure the video above covers everything. But in general. Remove the tires. Unbolt all the inside nuts. Cut the silicone to separate the 2 half's of the barrel. I believe the face can now be removed.
2000 Chevrolet Camaro Z28
Old 07-22-2012, 09:12 PM
19,69camaro 19,69camaro is offline
I hope its some other form of black because those look great as they are.
Old 07-22-2012, 09:53 PM
67XR7's Avatar
67XR7 67XR7 is offline
Fikse didnt get back to you? never heard of them having bad customer service!
1965 Chevelle, Pm me if interested in wheel tool rental
Old 07-23-2012, 09:28 AM
g356gear's Avatar
Thanks for the links. I wonder if you have to re-do the silicone after the center is unbolted or if you can just remove the center and leave the center hoops together.
Old 07-23-2012, 11:36 AM
The barrel has to come apart to get the wheel out. I disassembled my FM5's and this was the case anyway. If I was home I'd take some pictures of them apart so you could see but I am away from the house.
I like the way they look now. Only issue with black anodizing is in the sun some of them have been known to turn purple...Ask me how i know
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 07-25-2012, 09:22 AM
Sales@Dutchboys's Avatar
Like Jason said. I just did my fikses and didn't remove tires or split the wheel halves.
With all the bolts out, the center won't just fall out. Take a dead blow and lightly tap around it and they will fall right out.
Then when you put them back together just red loctite and torque to your specs.
dutchboyshotrods.com
269-823-2967
