Old 09-08-2012, 12:48 PM
Sieg's Avatar
Sieg Sieg is offline
Default Header Help!
I'm the process of getting AFR 190 heads with D-ports installed on my 69 Camaro and found out the hard way (opened the box) that the Hooker Comps I ordered won't work with the D-port. Contacted Hooker and they do not offer a product that works with these heads. So far I have inquiries into Summit, Doug's, and Heddman.
Need to find an option asap!
I can go short or mid length if required.
Thanks!
Old 09-08-2012, 02:05 PM
Sieg's Avatar
Question
Shorty from Sanderson supposedly designed for D-ports with 1-7/8" tubes
Less weight, heat, noise. Not ideal performance but probably not enough impact to matter in my application.
Old 09-11-2012, 02:54 PM
Sieg's Avatar
Anyone have experience with Doug's 368 model with Saginaw 700 box?
They work with the D-port but the 1 -3/4" tube layout is different than my current set-up:
Doug's 368
Doug's 308
This looks like it should clear the box but the oval 1-5/8" tube doesn't match up ideally to the D-port creating a curb in the lower corners.
Help!
Old 10-29-2012, 06:31 PM
69znc's Avatar
69znc 69znc is offline
Default New name to this board
www.elstonheaders.com
If you want great headers and, while not the cheapest, they are a small part of the build cost. I have had them on several cars and they are now on many friends cars.
If you want one of the best he can make them
Old 10-29-2012, 08:17 PM
badmatt's Avatar
badmatt badmatt is offline
Lemons, But far from cheap but some of the nicest headers.
97 Sonoma "NERA": Pile O Sh*t. Literally.
Old 10-29-2012, 09:07 PM
Sieg's Avatar
I ended up with the Doug's 368's and they fit great. The only nit-picks are had to trim the drivers upper control arm cross-shaft bolt to clear the #1 tube, the MSD plug boot is tight against #5 tube, and I can't get my Snap On swivel socket on plugs #5 & 7, short box end wrench is no problem though.
