Old 12-28-2012, 11:32 AM
PSV's Avatar
PSV PSV is offline
Default 69 camaro deluxe door panel question
I am looking for measurements of the door pull on the deluxe door panel please. I need the length and distance it sticks out ( height) of the door pull. The roll bar in my car interferes with the arm rest base on a standard door panel so I am thinking about using the deluxe door pull rather than the arm rest if the dimensions are close. Thanks!
Old 12-28-2012, 12:22 PM
g356gear's Avatar
g356gear g356gear is offline
I would think that the door pull would be in the exact same location for both interiors since the cars were going down the assembly line and were getting standard or deluxe.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 12-28-2012, 12:42 PM
PSV's Avatar
PSV PSV is offline
The standard door panel doesn't use a door pull as it is part of the arm rest. The standard arm rest base sticks out 3 inches from the panel and of course my down bar goes thru that area. Im hoping the deluxe pull is about 2 inches high and the same width.
Old 12-28-2012, 12:51 PM
PSV's Avatar
PSV PSV is offline
This is the part I need mesurements for please.
http://www.rickscamaros.com/camaro-d...1968-1969.html
Old 12-28-2012, 09:03 PM
JKnight JKnight is offline
It's 10.5" long (including chrome trim base) and sticks out 1 5/8" from the deluxe door panel at its' highest point.
Edit: I'd call it 10.25" without the chrome trim base as your link pictured.
Old 12-29-2012, 06:35 AM
PSV's Avatar
PSV PSV is offline
Thank you that's exactly the info I needed.
