Old 02-04-2013, 05:38 PM
jorgezee1 jorgezee1 is offline
Default LS1 carb cam - can I run this cam, should I run this cam
I have a 01 ls1 t56 setup going into a 69 camaro with a 3.73 gear. GMPP intake and a speed demon 750 with a nos 150 shot carb plate.
I have a cam it's a Thunder Racing 224/224 on a 114 LSA. can I run this cam or should I not even bother?
I also have the stock 01 corvette LS1 cam and an LS6 cam.
what do you guys think. buying another cam is still an option but if I can save 400 I would like to.
Old 02-04-2013, 06:34 PM
It's a good mild cam that will provide a noticeable but not terrible chop at idle. The powerband will be broad and work well with the trans and gear selection. Basically, it's a good hot rod or street/strip cam. Nothing radical but worth the time especially compared to the LS6 cam.
You can always go bigger and badder. Don't get caught up in that game though. Think about your goals and desires with the car and build for that regardless of what someone else does to their engine or car. Enjoying the car and achieving your goals with it matter most.
Old 02-05-2013, 01:16 AM
Rybar's Avatar
Rybar Rybar is offline
What Trey said, it's a mild cam but will make much better power than a stock LS1 or LS6 cam.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 02-05-2013, 12:03 PM
thanks for your input. makes me feel better. i know a 114lsa is not optimal for a carb setup, I was just worried it would run horrible. i will give her a try.
Thanks,
Jorge
Old 02-05-2013, 01:48 PM
NOPANTS68 NOPANTS68 is offline
Buy good pushrods and springs for this setup. they are a weak link in an LS1 with a cam swap. I would strongly reccomend some comp 7.400s and some patriot gold springs. A cam will make that engine come alive, but it will take some carb tuning. Let me know if you need help. Dave
1929 Roadster Pickup
1961 Chevy Parkwood Wagon
1956 Chevy 210
Smithcraft Collision and Restoration
Newcastle , CA
Old 02-06-2013, 06:33 AM
Why would the 114 LSA not work well with a carb? The factory cam is even wider ie larger LSA number. There are also plenty of cams that are tighter. Matter of fact, most people putting cams in LSx engines go 112 or tighter. The 114 cams are typically left for people with automatic transmissions who don't want a loose converter for street driving or simply to have a more mild idle while sitting in gear.
Patriot gold springs are good springs. In my opinion though, you don't need a double spring with that cam. I'd look towards Comp Cams Beehive springs. Either choice will be fine though. Definitely get a one piece pushrod set for the engine too.
