Old 08-17-2013, 03:10 PM
RBuhr69's Avatar
RBuhr69 RBuhr69 is offline
Default RideTech TruTurn Linkage
I went to hook up my TruTurn arms and ran into an issue...I'm sure it is my issue but the ball joint on the left (driver side) that connects to the draglink under the Pitman arm is hitting my header and cant even get it connected....Is this a common area that needs modifying/cutting the header to make room?
Just wondering....I have Headman Long tube headers if that that makes any difference if anyone else has ran into the issue before...
Just wondering if this is common....I put all new Pitman arm, and drag link on so nothing is bent......
Thoughts?
Old 08-17-2013, 03:50 PM
RBuhr69's Avatar
I guess part two of this question...
IS it worth the effort to modify existing headers or just buy new ones? And if that is the recommendations, what will work for SBC and Truturn system and clear?
Old 08-17-2013, 04:17 PM
Bad94 Bad94 is offline
Dynatech headers fit with a small block and truturn.
Above Average Motorsports
1972 Nova, Ride Tech, Forgelines, Wilwood, Bowler Transmission, Lingenfelter, RAFT.
Old 08-17-2013, 04:21 PM
RBuhr69's Avatar
Awesome ,thanks...
These the ones?
329-740-11210
MuscleMaxx Coated Header System
1967-69 Camaro
1968-74 Nova
Small-Block Chevy
1-5/8" - 1-3/4" Primary Tubes
4-Bolt, 3" Collectors
2.5" Reducers
Old 08-17-2013, 05:04 PM
Rod P's Avatar
Rod P Rod P is offline
its common that the header hits the Tru-turn, a muffler shop can cut-off modify that tube for just a couple bucks, and most times without even removing the header I had my shop modify mine for 20 bucks
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 08-19-2013, 10:38 PM
DarkoNova DarkoNova is offline
Banned
No disrespect, but are you sure you have them on the right side? I forget which is which, but one of the tie rods is bent for extra clearance. You might have them on the wrong side.
Just a thought.
