Old 11-13-2013, 02:55 PM
Restocreations's Avatar
Restocreations Restocreations is offline
Default 63 Split Window Corvette Restomod
Here is my current Corvette build.
I purchased this car this past January and started disassembling it on May 29th. The previous owner did a nice job building the car and it handled well for a stock frame with upgraded suspension, but when he was building the car the variety of aftermarket frames and ls motors were not available...there is only so much you can do with a stock frame.
When purchased...super nice car to start the project with.
May 29th: Disassembly/wet sanding with 600
Old 11-13-2013, 02:57 PM
32 Man hours total
Body completely naked of all exterior parts and glass(minus tail lamps), the paint has been wet sanded with 600 grit, all interior molding has been removed, rear carpet is out, and the door alignment has been adjusted as best as possible.
Checking door alignment
Old 11-13-2013, 03:00 PM
Also in early June
50 hours deep
I was watching overhaulin' the other night and saw how they were using tape to create a form for fiberglass, so i tried it on the firewall where the heater box hole will no longer be necessary thanks to the newer vintage air unit. It worked well, but i ended up needing to still put a layer of glass on the backside for support.
Clean slate
My opponent
Template for fiberglass mat made out of tape, which i then transferred to cardboard.
Firewall glassed in and sanded around area to be filled.
First skim coat of evercoat filler.
6/13/13
54 Hours Total
New dolley came in yesterday. I assembled it this evening and mounted it under the car. No big updates for now. I've been busy hustling to get another car ready for paint, so i havent had time to work on the 63 this week.
Old 11-13-2013, 03:01 PM
7/17/13 Took a day to work on the dash since the pads arrived.
57 hours
I started to work on some of the interior items in anticipation of the SRIII chassis and 63 hood arriving soon.
I wet sanded the dash, primed it in areas where i had rubbed through eliminating drips, and then repainted it with SEM hot rod black.
Wet Sanding
New Black Leather Dash Pads with French stitching option
Here (on the left, not the other gauges) you can see what the Autometer American Muscle gauges will look like with the original clock. I sold the cluster shown with the stock chassis. The new one will have the autometer gauges recessed behind the original cast in bezels.
Old 11-13-2013, 03:03 PM
8/21/13 I started working on the car full time and put my other projects aside.
64 hours
I removed a large majority of the old paint from the firewall and fender skirts, but still a lot to go before epoxy primer. At this point, i was also in the process of fitting the new components on the firewall and in the engine bay to insure everything fit correctly.
Making sure everything lines up with the new vintage air system. Still a good bit of body work to do on the firewall where i deleted the heater box cut out.
New wiper motor from Detroit Speed.
Seats recovered in new black leather.
Old 11-13-2013, 03:06 PM
70 hours
I really did not want to get this far into bodywork, but the door gaps on this car were massive at the front and rear and I just couldn't leave them that way.
Before
After, which ended up being too tight.
Smoothing out the firewall took a lot longer than i initially thought it would.
The hood finally was finished by shermersheim and arrived. Bolting it on made me realize that the hood surround is wavy from previous bodywork.
Love C2 coupes. Sounds like a great projects.
