Old 11-21-2013, 09:38 AM
Ben@SpeedTech's Avatar
Ben@SpeedTech Ben@SpeedTech is offline
Default A quick shout out for ATS spindles
Just a heads up, Speedtech/ATS has now upgraded our forged spindles! Rather than the C5 hubs we were using we'll now be installing the 2013 ZR1 Corvette hubs into both our standard height and tall spindles. Some of the advantages are:
Larger bearings that have more balls, literally.
30% Thicker wheel mounting flange that can handle more abuse.
Large variety of brake package options.
They're engineered for the top of the line ZR1 Corvette, so they ought to be good enough for for a pro-touring car, right?
Best part about it is that we're now providing an even better product without raising the cost at all to the consumer. How cool is that?
We have spindles available for Camaros/ F Body, Chevelles/ A Body, Novas/ X Body, G Bodies, and 94-96 Impala SS/ B Body. Check it out at- www.speedtechperformance.com
-Ben, Creative Director
Old 11-21-2013, 09:55 AM
Bad94 Bad94 is offline
Please work on a steering arm to run the tru turn.
Above Average Motorsports
1972 Nova, Ride Tech, Forgelines, Wilwood, Bowler Transmission, Lingenfelter, RAFT.
Old 11-21-2013, 12:43 PM
carbuff's Avatar
carbuff carbuff is offline
Originally Posted by Ben@SpeedTech View Post
we'll now be installing the 2014 ZR1 Corvette hubs
Wow, you heard it here first folks! GM is making a 2014 ZR1!
So was that supposed to be 2013, or just 2014 Z-51? I'm curious...
Old 11-21-2013, 04:56 PM
Ron in SoCal's Avatar
I could be wrong Bryan, but those look like z51s to me.
'13 Zr1s have 33 splines through the rear.
Ron in SoCal
69 Camaro in progress
Old 11-21-2013, 07:22 PM
mfain mfain is offline
Ron,
You are correct. I have a pair of ATS spindles with the 2010-up ZR1 (SKF) bearings that Blake set up for me a couple of years ago. They do have the splined hole through the middle of the bearing (the fronts and rears on the ZR1 have the same part number). I was curious about the "without raising the cost to the consumer" assertion since the ZR1 bearings are much more expensive. At first I thought Ben might have included an old file photo, but if you look at the front view, just below the indexing hub between the two lower wheel studs, you can see evidence of the hole that has to be drilled in the flange to insert a tool to spot face the larger ZR1 bearing housing for the lower ATS mounting stud. I specified, and Blake provided genuine GM bearings -- SKF makes them for GM. I don't know if someone else is now making "replacement" bearings (without the splines), but it would be worth asking the question. Ben?
Pappy
Pappy
Old 11-21-2013, 08:39 PM
carbuff's Avatar
I am curious if the hubs for the '14 and up C7 will work on the C5/C6 uprights. Somewhere down the road I'm sure I'll need a new pair, and would love to hear that GM upgraded the hubs for the newer model!
Old 11-21-2013, 10:08 PM
gerno's Avatar
gerno gerno is offline
Brian - I've got a brand new set of the ATS spindles ready for my car if you want to come check them out before I install them
