Old 01-05-2014, 11:30 PM
James OLC's Avatar
Default 2014 OLC Garage Sale - Lots of parts
Item Location (City/State): Central California
Price: as listed below plus shipping
Description:
Updated March 19th, 2014
I'll add pictures and a few more parts over the next day or two as I get info loaded up... More pictures and information is also available on my Facebook page at https://www.facebook.com/OLCGarageSale
1967 Camaro custom modified front subframe (will fit 1967 - 1969 F-body and Nova). Fully seam welded, converted for coil overs using SpeedTech ATS Chicane kit, SpeedTech high clearance upper and lower control arms, ATS AFX billed spindles with SKF hubs and ARP wheel studs. Custom modified centerlink, 2nd gen outer tie rod ends, custom built steering arms, custom valved RideTech triple adjustable shocks with Hyperco coil springs, Baer 14" rotors, Lee Engineering 670 Steering box, ATS LS engine mounts. Also includes all stainless steel brake lines. First Chicane subframe built by ATS and featured in the 2008 SEMA Show. Subframe was powder coated (titanium) and then sanded and painted.
and
ATS Tri-Y stainless steel headers and 3" Magnaflow exhaust system. Custom modifications to the headers to address low hanging collectors common with these rare pieces. Fit all LS engines including LS7, can include new ls7 header gaskets and bolts. Exhaust system includes Magnaflow true-x crossover and stainless mufflers. Ridicules amount of work done on exhaust (welds ground smooth, etc). Entire system - headers, exhaust, and mufflers - Jet Hot coated (titanium finish).
This is a bolt in and go solution to get your LS project up and running fast immediately.
I have $8500 in parts/labor and countless hours/$s in tuning on the subframe and $4500 in the exhaust - asking $8000 plus shipping (prefer local pickup) - will not separate
LS7 Intake Manifold and stock Fuel Rail. Like new but with one dyno pull. Does not include injectors or TB. Asking $250 plus shipping
LS7 fuel rail (stock - no injectors, no intake) - dyno time only - $80 plus shipping
FAST Fuel Rails and Fuel Rail Crossover Kit (PN 146027 and 54028) Both are new and unused. Fuel Rails still in sealed box, crossover lines were opened but not used. Don't want to separate, asking $240 plus shipping for both
McLeod 8710-10 SFI Approved bell housing - sold
Powermaster LS "mini" Starter - PN 9509 - sold
Canton 22-480 Remote Oil Thermostat - includes -12AN O-ring fittings as shown. Used but in excellent working order. Includes mounting bracket. $120 plus shipping.
Willans Club Silverstone 5-point cam-lock harness. Blue, certified through 2013 (sub belt through 2014) – new in the original packaging, never used. Retail is $350, asking $200 plus shipping
Anvil carbon fiber hood - PN 010043: Satin 67-69 100% Carbon Fiber Bare Hood, Used - body worked and painted by Best of Show, Includes 1 vent with screen - needs 1 vent with screen - Ring Brothers Hood Pins available as well for $150 (Set up for hood pins but can use stock latch as well)- $1100 plus shipping
Setrab Oil cooler - P/N 50-925-7612 - used. 16" x 7.6" x 1.5", plumbed for -12AN (fittings included) - perfect working order. Asking $200 plus shipping.
GM LS7 Oil Pan Gasket - PN 12612351 (qty 1) - new. Asking $50 plus shipping
Chase Cam System #1 - $450
PDR100 recorder
600 line bullet camera
Standard Camera mount
5' Mini DIN camera extension cable
Remote AA Battery pack
Chase Cam System #2 - $500
PDR100 recorder with G-force meter (auto start)
Suction cup mount mount
Standard camera mount
Cigarette lighter power adapter
PIM10 Power Isolation Module
Buy both systems and I'll through in a dual recorder mounting kit ($89) and a case.
McLeod RST Cutch - $250 - Part Number 6912-07 - aka "Smokey" - SOLD
McLeod RST replacement clutch disks (front and rear disks) - $240 (pair) - SOLD
Kinsler Spec Bosch 10211 Fuel Pump – new in the box (was an OLOA spare) – Retail was $360, asking $300 obo plus shipping.
Track Rat Engine - - SOLD
Wheels (will update backspacing ASAP):
HRE Comp 93 (C93) Wheels 19 x 10.5" - Satin Black Powdercoat Center, Brushed and Clear coated outer hoop and satin black powerdcoated inner; Step lip. $1,900 (pair) plus shipping
HRE Comp 93 (C93) Wheels 18 x 9.0" - Satin Black Powdercoat Center, Brushed and Clear coated outer hoop and satin black powerdcoated inner; Step lip. Offset is +36 with an 8.0" inner and 1" outer. $1,900 (pair) plus shipping (available with NEW Michelin Super Sport 275/35-18 tires, excellent condition for an additional $400)
HRE Comp 93 (C93) Wheels 19 x 12.0" - Satin Black Powdercoat Center, Brushed and Clear coated outer hoop and satin black powerdcoated inner; Step lip. Offset is -3.9 with a 7.0" inner and a 5.0" outer. $1,900 (pair) plus shipping (available with Michelin Super Sport 305/30-19 tires, excellent condition for an additional $300)
Tires:
Michelin Pilot Super Sport tires 2 x 325/30ZR19 - $750 (pair)
New - never mounted - perfect condition
Marked for 2012OLOA
Michelin Pilot Super Sport tires 2 x 305/30ZR19 - $600 (pair)
Used one track day - minimal tread wear - perfect condition
Marked for 2013OLOA
Michelin Pilot Super Sport tire 1 x 305/30ZR19 - $300 (each)
Marked for 2013OLOA
Michelin Pilot Super Sport tires 1 x 325/30ZR19 - $375
New - never mounted - perfect condition (located in IL)
Marked for 2012OLOA
Michelin Pilot Super Sport tires 1 x 275/35ZR18 - $200
Marked for 2012OLOA
... everything is first PM or Email, first served. Prices do not include shipping
Parts are in Central California (unless otherwise indicated) so delivery within California might be possible depending on timing and location.
Thanks for looking!
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 01-06-2014, 09:28 AM
califconstruct's Avatar
califconstruct califconstruct is offline
Default HRE wheels.
P.M. Sent.
Old 01-06-2014, 11:24 AM
ADiCarlo ADiCarlo is offline
PM Sent last night.
Old 01-07-2014, 12:00 AM
James OLC's Avatar
All PMs replied to.
Since I can only add so many pics to a single post, here are some of the HRE wheels:
Cheers and thanks again for looking
James
1969 Camaro - Dusty
Old 03-05-2014, 09:11 PM
dcrider69 dcrider69 is offline
Is the complete clutch from the other post still available?
Old 03-08-2014, 06:53 AM
Thebigtomato Thebigtomato is offline
Default Wheels
I was wondering if the wheels have been sold yet? Please let me know , thanks.
