Old 02-04-2014, 04:11 PM
TK442 TK442 is offline
Default LS conversion
New member here I'm doing a LS swap in a 1977 442 what is the best way to do the fuel situation any thoughts
Old 02-07-2014, 11:55 AM
Bigbore500r Bigbore500r is offline
If you are going external pump, the newer Holley EFI pumps are awsome. Totally silent, even when mounted straight to the frame. Your stock tank will have issues when fuel level is lower, during hard braking or turning. If that bothers you, I would look into a new tank and at that point do an in-tank setup since you are replacing the tank anyway. Aeromotive makes a drop in unit that installs where a typical sending unit is
Old 02-07-2014, 06:09 PM
Ok thanks I didnt see the drop in unit from them but I see their fuel cell set up I thought that was a good clean look. Which way would you go?
