Old 05-16-2006, 04:52 PM
comp-spec's Avatar
comp-spec comp-spec is offline
Default which master are u using
Im running wilwood 6 piston front and wilwood rears. What master are u using (non power). Trying to get rid of a hard pedal.Brakes are up under the dash so space is tight.
Old 05-19-2006, 05:50 AM
TravisB TravisB is offline
I have one of wilwoods pedal kits.....for my car! Do you need the bore size???
Kenny Davis Hot Rods
Old 05-19-2006, 05:20 PM
comp-spec's Avatar
Trivis
Im running a wilwood now 1in bore and the petal is too hard ,going to try a 7/8 and see if its any better. Just wondering what every one is using with (non power) big brakes .
Old 05-21-2006, 10:14 AM
awr68's Avatar
awr68 awr68 is offline
I have the Wilwood 6 piston (front) and 4 piston (rear) set and was told to use a 1 1/8" bore for non-power, so I bought a late model S10 master, hope it works!!
Tony
'68 Camaro
Old 05-22-2006, 11:47 AM
comp-spec's Avatar
awr68
I was told to use a smaller bore (7/8), who told u to use a 1 1/8 ??
Old 05-22-2006, 12:17 PM
4mm 4mm is offline
Use a smaller bore for lighter pedal feel. I have a 7/8 on six piston wilwood fronts and the pedal is still very hard to push.
Old 05-22-2006, 04:59 PM
awr68's Avatar
Originally Posted by comp-spec
awr68
It was either Wilwood or Precision...pretty sure it was Wilwood though....
Does the stroke have anything to do with it??? (Allan leave that one alone!!)
Tony
'68 Camaro
