Old 07-22-2014, 05:46 PM
70 tt rustang's Avatar
70 tt rustang 70 tt rustang is offline
Default Teflon lined hose or standard braided
Hi all iam at the point where iam intalling my new fuel system. I wanted to get a second opinion on choosing the line for my EFI fuel system. Iam running pump gas. I was running standard braided line before with no problems but ive been told that over time like 3 years that the line due to the ethanol in the gas will make the line bleed vapor giving a gas smell and then become hard and have to be changed. On the other hand ive heard nothing bad about the teflon line besides the price. Does anybody have any fuel line opinions?
thanks
Rich
Old 07-22-2014, 06:35 PM
Greg from Aus's Avatar
Greg from Aus Greg from Aus is offline
Yep Teflon all the way.
Old 07-22-2014, 09:25 PM
intocarss's Avatar
Yes.... PTFE / Teflon Is the only way to go
Old 07-23-2014, 04:43 AM
dontlifttoshift's Avatar
dontlifttoshift dontlifttoshift is online now
Teflon hose is great but I never cared for bend radius or assembling the fittings. The Brown and Miller corrugated Teflon sounds perfect with crimped fittings but I have never had it in my hand. Then there is the braided stainless housing, I just don't care for it and prefer a cloth wrapped hose in black.
I have been using Viton hose from Phenix that is E85 compatible, so a little bit of ethanol is no big deal.
http://www.phenixindustries.com/prod...ss-inner-hose/
Donny
Old 07-23-2014, 05:05 AM
OBeer-WAN-Kenobi's Avatar
Go PTFE but do NOT buy the Summit or Jegs branded fittings. You can't get the things together, which may have been dontliftoshift's problem. There is obviously a manufacturing issue with those things and I did call those guys to tell them their stuff is junk. After I switched to Aeroquip fittings, I had zero issues. The bonus is you can use the same line for power steering and other high pressure applications.
There are a couple of tools that will make your life easier. A braided hose cutter and a doohickey that separates the braid from the PTFE. You can also try a cut off wheel. The heat produced will usually separate it for you.
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 07-23-2014, 07:40 AM
hifi875's Avatar
hifi875 hifi875 is offline
i used the Earls fuel line when i installed my terminator efi. stuff was very easy to work with and best of all it doesn't leak. which is amazing since i made all the cuts and installed the ends myself. it is their new stuff that is ptfe
69 camaro
03 z06
90 mustang coupe
1950 international l110
1993 mustang gt
Old 07-23-2014, 04:32 PM
We just got some of the Brown & Miller stuff for my fuel system recently from their Socal branch. Super nice and light stuff. A little spendy.
Old 07-23-2014, 07:53 PM
Che70velle's Avatar
Is the Brown and Miller hose a PTFE hose? I haven't heard of them before.
Thanks Dad!!
