Old 10-25-2014, 10:06 PM
kevin_l's Avatar
kevin_l kevin_l is offline
Default falken azenis rt-615k or BFG rivals for street tire?
I am limited between these two choices. I need 265/35r18 and 315/30r18. Not many options if I want to keep tread pattern the same front and rear. I am mainly using the car for street use.
I am open to other choices but I am wanting to stay under 1500 Thanks
Old 10-26-2014, 11:57 AM
carbuff's Avatar
carbuff carbuff is offline
I haven't driven on the Rivals, but I run the Falkens on my car. I've put about 3700 miles on them with several autocrosses and a track day. I have over half of the tread left, and the performance at the autocross has been good.
I'm sure Rival owners will have similar impressions of those.
Old 10-26-2014, 05:21 PM
kevin_l's Avatar
What kinda of life would you guess on only street driving?
Old 10-26-2014, 08:45 PM
carbuff's Avatar
10k miles perhaps? Hard to say really. I figure I'm about halfway through this set, so I'll probably get 7k out of them depending on what type of events I do next year.
Old 11-05-2014, 08:32 AM
Formula43 Wheel's Avatar
Formula43 Wheel Formula43 Wheel is offline
Both tires are excellent and get good reviews. Michelin Pilot Super Sports are also an excellent choice for both street and track use and will be more friendly for cold or wet weather conditions.
Rival's currently are only available from Tire Rack, but I here that is going to change as of the first of the year. Note: Rival's need a full heat cycle to be effective on the track. Falkens are more expensive and can be purchase online and also at Discount Tire.
Also, Dunlop has some excellent new tires and I like the Bridgestone SO4 tire as well.
I would recommend a 275/35-18 front size as it is a little taller than the 265 tire.
Good Luck!
Old 11-05-2014, 09:09 AM
dontlifttoshift's Avatar
Good Luck!
Have you heard anything about a new compound?
One moe for Michelin SuperSports on Mostly street car that may see some light track duty.....or even some heavy track duty. Great tires, ride nice, wear well.
Donny
Old 11-06-2014, 08:50 PM
kevin_l's Avatar
Good Luck!
Thanks for the advice, I'll have to check but I think the only 2 options with matching front and rear where the rivals and 615k. Maybe I skipped over the others because of higher price. The rivals are cheaper than the falkens but I am mainly after decent wear. AutoX is on the back burner, strong driver is my number 1 goal at this point.
