Old 04-28-2015, 09:11 AM
Swain's Avatar
Swain Swain is offline
Default Spectre Dealer
Anyone on here a dealer?
How are their LS Swap intake set ups?
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 05-02-2015, 05:15 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
I used the Spectre LS Swap I take on my LS7 69 Camaro. I did not use the heat shield because it didn't work with my TCI sub. Drivers side filter. I was very pleased with fit and function.
I'm using the same set up on the LS3/525 car I'm building now.
I spoke with a Guy at Spectre this week. The kits are being redesigned and not available at this time. The only part of the redesign is the heat shield which I'm not using so he gave me the part #s I needed to put it all together.
Best pricing for the individual part I found was via Amazon.
Last year I did an LS3/480 69 Camaro and used Airaid LS Swap intake. It also worked out nicely and Airaid was great to work with. Their system comes with an Air Box and close out panel. We called Airaid and they sent us a matching panel for the pass side. I had moved the battery to the trunk and installed the GM Performance fuse box in the battery tray for easy access. The close out panel hides everything but still allows easy access.
Old 05-02-2015, 11:19 AM
Vage$69 any pictures of these installed in the cars?
Old 05-02-2015, 11:37 AM
Vega$69's Avatar
The LS7 Car
The LS3/480 Airaid
Air box with filter Black ABS 908 tube goes from TB to airbox.
I'll try to find a pic.
Matching pass side cover
Old 05-03-2015, 07:55 AM
cpd004's Avatar
cpd004 cpd004 is offline
I have one on my 71 Ls3. The heat shield didn't fit but it's because of the way I have my overflow and radiator set up. Otherwise, it's well made. You have to weld in the MAF mount on your own.
1971 Firebird
2017 SS
Old 05-03-2015, 03:56 PM
It looks great, it's a nice set up .
