Old 02-02-2016, 01:50 PM
zboss zboss is offline
Default dies for cage building
Building a main hoop for a 69 Camaro out of 1.625 chro-moly. What radius are you guys using?
Old 02-02-2016, 02:39 PM
Blake Foster's Avatar
5" or 5.5"
Blake Foster
www.speedtechperformance.com
Old 02-02-2016, 03:46 PM
djorgensen3 djorgensen3 is offline
Default radius
I think mine are 6" but don't hold me to that...
Old 02-02-2016, 07:44 PM
I looked into this before purchasing my 1.625" die as well. The advice I got was to buy the smallest CLR available that is spec'd to bend the minimum wall thickness tube you are bending.
I was bending 1.625" .083 wall which happens to be the minimum wall thickness on the JD2 Model 4 5.5" CLR die so that's what I got. So far, so good. I've bent some 90 degree bends and haven't noticed any issues.
John
John
'71 Nova (Build thread)
FFR Roadster
Old 02-03-2016, 01:03 PM
Keep in mind that some race club rules have .120 wall thickness minimum. Making the chromo useless
Old 02-04-2016, 09:28 AM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
Also, some sanctioning bodies specify a minimum bend radius. For example the SCCA specifies that the bend radius must be a minimum of 3 times the diameter of the tubing. So 1.75" diameter tubing must have a minimum radius of 5.25"
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
