Old 05-18-2017, 09:12 AM
Try2paz's Avatar
Try2paz Try2paz is offline
Default New Motor for the Mustang
Having Elliot at Mustang Corral build me a new motor for the Mustang...we're also going to change over to EFI and fuel system. (intank pump, baffles etc)
New Combo:
410 cubic inch Windsor Engine
Dart S.H.P. block 4.125 bore
Scat 3.850 x 4.125 rotating assembly
A.F.R 205 Aluminum heads
Solid flat-tapped cam and lifters
5/16 hardened push-rods
Competition cams roller rocker arms
Melling select H.V. oil pump
Victor Jr. Intake Manifold
A.R.P. bolts
Mcleod 10 inch twin disc clutch/flywheel assembly
Old Motor coming out: I'll be reusing the distributor and pan.
Now the rush is on to get it back together before Shelby Mini-Nats
1967 Nova
2018 Camaro ZL1 1LE
Old 05-18-2017, 01:03 PM
DBasher's Avatar
DBasher DBasher is offline
No problem!
What are you doing with the old set up?
Old 05-18-2017, 02:21 PM
Try2paz's Avatar
i'm not sure what i'm going to do with the old setup, maybe keep it as a spare..
I'm going to send it by my local machine shop to have it freshened up at some point. It's not a bad motor it made 350 RWHP at 5500 RPM and I spun it to 6100 so i'm sure its a 370 ish RWHP motor. Why you interested?
1967 Nova
2018 Camaro ZL1 1LE
Old 05-18-2017, 06:36 PM
DBasher's Avatar
I'm always interested in used Ford parts. Concentrate on the new motor and keep me posted on the old.
Old 06-06-2017, 03:57 AM
70 tt rustang's Avatar
70 tt rustang 70 tt rustang is offline
Hi iam looking into getting that maier tower brace. I have efi on my Windsor thou, have you had any issues with valve cover removal or dizzy removal?
Also did you paint the bar?
Old 06-06-2017, 10:52 PM
DBasher's Avatar
I've got one on the wife's car and have no issues with clearance. Valve covers clear fine and just take a bit of routing to get them out, the distributor is close but removing the cap makes R&I a lot easier.
I think Ford and the aftermarket have different height distributors, probably best to call Mike. I know he'll make the bars to any angle needed.
Mine came powdercoated.
Old 06-08-2017, 03:13 PM
Try2paz's Avatar
Mine also came powdercoated... no issue with the valve covers going in our out but the distributor is tight but it works. I've got a MSD pro setup.
Some motor pulling fun!
I got the motor with the car and didn't know much about it other than it being a 351...i think it had a flat cam from the start as it should have been a "healthier" motor so to speak.
This motor has the right components to be a good motor so it will also take a trip to the machine shop.
I just dropped of the car at Mike's Maier and we're going to pulling the shock towers and covert over to 67 towers. So while the motor is being built a little extra work up front is going to take place.
1967 Nova
2018 Camaro ZL1 1LE
Old 06-08-2017, 04:51 PM
booah booah is offline
Mike Maier Inc now sell a DYI shock tower brace so you can get the clearances you want and have the same pick up points.
https://mikemaierinc.com/product/mus...k-tower-brace/
