Old 08-13-2017, 05:12 PM
DT69Cam DT69Cam is offline
Default TKO in 1st gen camaro (hole size)
What size shifter hole you guys cut for a TKO in your 1st gen Camaro ?? I have a new 1 piece floor installed and wanted to make a clean round hole. Just not sure what size. Thx
69 Camaro Convertible (LS3/TKO in the works)
Old 08-13-2017, 06:08 PM
Gregster1234 Gregster1234 is offline
Here's my install - TKO600, I haven't bolted the trans mount yet thus why it is not centered. I used a 4" metal holesaw.
Old 08-13-2017, 06:09 PM
Thank you very much!
Old 08-13-2017, 08:01 PM
JKnight JKnight is offline
You can probably get away with a slightly smaller hole in the tunnel than Greg's pics but this is one of those things where you don't need to be too precise. Just need the clearance Clarence.
Old 08-14-2017, 11:43 AM
Thx for the reply. I was curious what other guys did. I could even just cut out the exact size of the shifter plate (for lack of better description). Its almost a rectangular shape.
