Old 10-20-2017, 12:17 AM
Forgeline Wheels's Avatar
Default Robert Ortega's "LS3.Velle" 1970 Chevelle on Forgeline GA3R Wheels
Where do you draw the line between grand touring and pro-touring? Robert’s 1970 Chevrolet Chevelle is powered by a 485HP LS3 and rides on a full Detroit Speed suspension, JRi coilovers, Wilwood disc brakes, 315/30ZR18 BFGoodrich Rival S rubber, and 18x10.5 Forgeline GA3R wheels finished with Matte Black centers & Gloss Black outers! See more at: http://www.forgeline.com/customer_ga...w.php?cvk=1987
Mark Schetter
Forgeline Motorsports
3522 Kettering Blvd
Dayton, Ohio 45439
O: 937-299-0298 x12
F: 937-643-0070
[email protected]
www.forgeline.com
Old 10-31-2017, 01:20 PM
Notalent's Avatar
Notalent Notalent is offline
Perfect stance and look. Is this mini tubbed or anything need to be done to fit that width in the rear?
1971 Chevelle
ATK Engines 496 Stroker 675HP
TH400 / 9 Inch 3500 Stall
http://brandons71chevelle.weebly.com/
ATK HIGH PERFORMANCE ENGINES
WWW.HIGH-PERFORMANCE-ENGINES.COM
Old 10-31-2017, 10:48 PM
Nope. Tony G is even running 11s without minitubs on his ABC Performance Chevelle. The only problem that we sometimes see is that if the rear fenders have been replaced and are not in the exact factory locations, then things can get off center. But if everything is correctly located, then you've got lots of room.
Mark Schetter
3522 Kettering Blvd
Dayton, Ohio 45439
O: 937-299-0298 x12
F: 937-643-0070
[email protected]
www.forgeline.com
Old 11-03-2017, 10:50 AM
Notalent's Avatar
Wow....good to know. Can you PM me a price for the same setup shipped to 75050?
Thank you.
1971 Chevelle
Old 11-07-2017, 06:10 AM
Thank you.
Sending PM now!
Mark Schetter
3522 Kettering Blvd
Dayton, Ohio 45439
O: 937-299-0298 x12
F: 937-643-0070
[email protected]
www.forgeline.com
Old 11-03-2017, 11:39 AM
315's fit all 4 corners but once you compress the suspension that's where tires can rub .... tony modified the front inner fender to give him a little more clearance with turning and compression . id highly recommend calling abc performance and ask him . super nice guy
