Old 02-20-2019, 08:10 AM
NickBurns NickBurns is offline
Default TR6060 MG9 transmission mount and Crossmember
Hey folks - I’ve been searching high and low for some possible combinations to work with a Detroit Speed subframe. Seems no one makes a kit that works with confidence. The MG9 TR6060 (2015) mount bolts up to the side of the transmission. Does anyone know of a combination that works well with the Detroit subframe? I have the Detroit engine mounts with standard setback.
Nick's son was last seen finishing up his 1968 Pro Touring Camaro
1968 Pro touring Camaro
ALL DSE Suspension
2017 6.2L made of steel balls
Old 02-20-2019, 09:14 AM
Maybe I'm misunderstanding the question. Are you looking for a crossmember that works with the DSE frame for a TR6060?
I dont know specifically for the 6060, but my T56 Magnum works well on the hooker blackheart crossmember in my DSE frame.
PART# 12626HKR
Can see it a bit in this pic (old pic so can get more recent if you'd like).
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 02-20-2019, 05:49 PM
Thank you for the reply but the TR6060 is longer and the mount actually attaches to the sides. This has become the issue. I wish I knew for sure that I could use this cross member since I have the headers . I may have to purchase it and do some fabbing. I thought for sure someone would of solved this issue by now.
ALL DSE Suspension
Old 02-20-2019, 06:14 PM
Is something like this an option?
http://www.brphotrods.com/products/T...etc/index.html
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 02-20-2019, 06:18 PM
Originally Posted by will69camaro View Post
Hmm now I am confused - I did order the CNC spacer from these guys but when I received the transmission I realized the bracket attached to the two sides? Maybe I was sold a standard TR6060 transmission not the MG9? I asked and made sure they said it was a MG9
ALL DSE Suspension
Old 02-20-2019, 06:59 PM
To be fair i'm not familiar with the differences. But i bet you can find something.
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 03-22-2020, 07:14 PM
Thank you ! Yep very odd. I ended up buying the mount cut it apart and made my own! Much better than the one I bought !
ALL DSE Suspension
Old 03-26-2020, 08:05 AM
billohio billohio is offline
I figured out my situation recently. The CTS-V used a different tail shaft housing compared to the ZL1. Both are MG-9 but different tail shaft housing. I was concerned on what I had that is wasnt the MG-9 but it had the same serial numbers as the engine. That is the difference and the need for 2 mounts.
Old 03-26-2020, 08:06 AM
Ahh I forgot about that option as well. Mine is from Holden. What mount did you go with ?
ALL DSE Suspension
Old 03-27-2020, 10:02 AM
I have hooker motor mounts and got the blackheart crossmember and the poly mount. I am getting ready to see how it fits but may need to modify the crossmember. I never found much info on how this will fit. I may try and see if I can reuse the bracket that bolts to the transmission or make something
