Old 10-04-2019, 04:41 AM
paulk68 paulk68 is offline
Default Enlarging Rotor center holw
So my baer rotor won't fit over the moser axle register. has anyone opened the rotor center hole before? gonna find a machine shop to do this for me. but just wanted to see if anyone had run into this issue before.
Old 10-04-2019, 06:34 AM
Oleyellar Oleyellar is offline
Default Been there done that
Yes, I had to open the hole for my Moser axles. I also had some issues with the park brake drum inside the rotor that I had to fix. Different rotor than yours, single piece but it came from Baer with the SS4 rear kit.
Old 10-04-2019, 06:52 AM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
Haven't seen it in a while but it's happened to us before;
Pretty cheap to have a machine shop open it up a bit!
-Dale
SchwartzPerformance
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 10-04-2019, 07:40 AM
-Dale
Dale would it be easier to open the rotor or have the axle register turned down?
Old 10-04-2019, 10:47 PM
JKnight JKnight is offline
I’d mess with the rotors before the axles. Your next set of rotors may fit fine but if you turn down the axle....
Old 10-05-2019, 03:39 AM
Thanks guys Looks like it was built for willwood rear brakes when it should have been Baer. So I may open the rotor up to the 3.060 hub. just want to check with baer that it will not affect the hub at all.
Old 10-04-2019, 07:39 AM
I had an issue with the rotor not fitting over the parking brake. Baer walked me through how to reset the pin inside to free up the shoe.
