Old 03-11-2021, 03:39 PM
vet57air's Avatar
vet57air vet57air is offline
Default LT4 crate engine no start
Tried to start my crate LT4.... not a sputter. Fuel pump ramps up and I have fuel at the engine. ECU gives me a PO 00006 code, from which is suppose to be for a fuel shut off valve. Can see nor smell fuel on plugs. On the back of the engine I know of two plugs one on each side for the injectors and one other on the drivers side that looks like its for the intake (maybe pressure)? Anyone know where this valve is located? Is there a plug for it?
Old 03-11-2021, 04:26 PM
vet57air's Avatar
I see in the GM manual it makes mention of a "soak and idle" which is to connect the battery for 8 hours before starting. "Turning on the ignition for any length of time may cause you to have to soak an additional 8 hours". I didn't do the soak. Could that be the issue?
Old 03-11-2021, 05:14 PM
randy randy is offline
I kept on resetting the check engine light and it eventually started
The Following User Says Thank You to randy For This Useful Post:
vet57air (03-11-2021)
Old 03-11-2021, 05:36 PM
vet57air's Avatar
Thanks for that. I will give it another try tomorrow. Do you know what code came up in your case?
Old 03-12-2021, 08:49 AM
vet57air's Avatar
Got it running this morning. I had cleared the active code PO 00006 yesterday.
So I imagine it was that or it needed the "8 hour soak and idle"
The Following 5 Users Say Thank You to vet57air For This Useful Post:
130fe (03-12-2021), andrewb70 (05-07-2021), camcojb (03-12-2021), dhutton (03-12-2021), srode1 (03-13-2021)
