Old 05-29-2024, 11:39 AM
Ns RS's Avatar
Ns RS Ns RS is offline
Default Need 69 trunk lid to be more flush
Not much of a body guy but what adjustments do I need to make so that the trunk lid closes lower/more flush?
Old 05-29-2024, 01:15 PM
What trunk seal are you running? Can make a huge difference, some of the repro stuff is too stiff and will never sit right. Did you check it without a seal in place?
Ns RS (06-13-2024)
Old 05-30-2024, 09:03 AM
bk2life bk2life is offline
first thing, like stated above, take off the decklid seal and see how it sits.
then loosen and remove your trunk latch and see how flush it sits...BE CAREFUL, no seals = metal on metal scratches when doing this.
if the rear (tailliat) portion sits correctly but the front (rear window) sits hihg then you need to adjust the deck lidk hinges to bring it down.
It's a pain in the rear, but thats why we get paid so much to adjust gaps.
let us know what you find
The Following 2 Users Say Thank You to bk2life For This Useful Post:
camcojb (05-30-2024), Ns RS (06-13-2024)
Old 05-31-2024, 05:54 AM
dhutton dhutton is offline
If it’s still sitting high without the seal then adding a shim under the rear most hinge bolts between deck lid and hinge should lower it. 1/8 should make a significant improvement.
If it’s the seal pushing it up Metro makes a seal with a hollow core that compresses more easily. If that doesn’t work don’t be afraid to cut the seal down on the side that installs in the gutter channel so it can’t be seen.
https://www.summitracing.com/parts/mmp-tk46-o
The Following 2 Users Say Thank You to dhutton For This Useful Post:
camcojb (05-31-2024), Ns RS (06-13-2024)
Old 06-13-2024, 04:04 PM
Ns RS's Avatar
yes the seal I had was solid and was making things uneven, i ordered the recommended hollow version, Installed and now I’ve got factory gaps which I can live with - nice to have a simple solution and I took many naps getting it done - thanks all 🤙
The Following 2 Users Say Thank You to Ns RS For This Useful Post:
camcojb (06-13-2024), dhutton (06-14-2024)
