Old 10-01-2006, 06:42 PM
rsk68's Avatar
rsk68 rsk68 is offline
Default Help No Oil
Hi guys
I just noticed when i pulled a valve cover off that there is no oil going to the rocker arms, It only has around 8 minutes of run time on it, What could I have done wrong here, I never had this problem before, a friend of all of ours put this together for me and i just put in the lifters, push rods and rocker arms, what the hell is up any one seen this before? I'm scared i may need to pull this thing out and tear it apart.
RSK68
Rick Klein
Hood-latches.com
Cast Aluminum hood latches.
Old 10-02-2006, 06:06 AM
Payton King's Avatar
Default not sure what motor we are talking about
I have seen it happen with the lifters not oiled up or primed, broken oil pump drive and one time when someone left the oil galley plugs out (small block chevy) during the rebuild
Old 10-02-2006, 07:13 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Probably should of checked this out by pre-lubing it, prior to running.
Engine type would help too, .
Old 10-02-2006, 07:45 AM
rsk68's Avatar
Default Help No Oil
I primed the motor but with the valve covers on, motor is a 68 Big Block 396
I'm thnking an oil gally plug is missing @*#*!
RSK68
Rick Klein
Hood-latches.com
Old 10-02-2006, 08:03 AM
MarkM66's Avatar
I'd remove the valve covers, spin the pump and slowly rotate the engine.
I know on a sbc, there is a plug that goes between the inlet and outlet to the oil filter, if it's not there or pushed up to far, oil will not go to the cam/lifter area. Pan must be removed to intall plug, it's near the rear main seal.
This happened to me when building my 383. Oil would not go up to dist/cam. But sill showed oil pressure, becasue I had my sending unit near the filter, and not up at the distributor.
I would think bbc would be the same. I'd have to check my assembly manual.
Old 10-02-2006, 04:33 PM
3kidsnotime's Avatar
3kidsnotime 3kidsnotime is offline
Take and put a manual oil psi gauge in the block on the lower lh side above the filter, pull your dist, and install a priming tool NOT a cheap one with out a body on it you have to seal the dist hole to provide psi to the upper end (the ones that are just a rod wont supply upper oil) and prime it and see what kind of psi you have there first. If you have good lower psi the 2 1/4 npt plugs behind the timing chain are probably not in. Good Luck
Old 10-03-2006, 03:42 AM
Also double check that you dont have a 65 block some early 66 they require a camshaft with a oil relief on the rear bearing surface
