Old 04-19-2007, 05:02 AM
MaxHarvard's Avatar
Default shaking badly at cruising speeds
the vibration starts around cruising speeds, 60-65mph, in 4th 5th and 6th gear, the entire car shakes.... bad. im taking the driveshaft back to the guy who shortened it so if he didnt balance it right... any other suggestions?? Pinion angle looks to be decent..
as a test i went up to cruising speed, felt the vibration, then put it in neutral and it still vibrated.
Thanks!
Old 04-19-2007, 06:10 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Driveshaft would be the first place I'd look since you just did the T56 swap. While your under there, check the pinion and driveline angle.
My LS7 69 Camaro
Old 04-19-2007, 07:05 AM
driveline angle. Can't look at it and tell if it's okay, you need to measure it. I usually go with 2-3 degrees down on my street stuff.
Old 04-19-2007, 08:26 AM
Payton King's Avatar
Default my bet is the driveshaft
Not balanced or the u-joints are not lined up front to back.
Did you do your own cross member or did you get one from Tyler?
Get a protracor from Home Depot for about $12. Just like Jody said about 2 to 3 degrees "down" at the trans and the same amount "up" at the rear end.
Old 04-19-2007, 08:31 AM
FYI, almost all tire vibration starts at 60 MPH to 65 MPH and goes away at 70 MPH to 75MPH. If you can drive through it, its tires. If it gets progressivly worse, it is drivetrain as you never drive out of drivetrain. Based on your trouble zone of 65MPH which is the sweet spot for tire shake, I am betting tires. If it is in the seat of you pants, its rear tires, in the steering wheel, up front.
Frank Serafine
Old 04-19-2007, 09:05 AM
Silver69Camaro Silver69Camaro is offline
Originally Posted by ProdigyCustoms
FYI, almost all tire vibration starts at 6 MPH to 65 MPH and goes away at 70 MPH to 75MPH. If you can drive through it, its tires. If it gets progressivly worse, it is drivetrain as you never drive out of drivetrain. Based on your trouble zone of 65MPH which is the sweet spot for tire shake, I am betting tires. If it is in the seat of you pants, its rear tires, in the steering wheel, up front.
Tires are my guess too. Doesn't sound like a driveshaft to me.
Be sure to update us, I'm curious!
Matt Jones
Mechanical Engineer
Art Morrison Enterprises
