Old 09-24-2008, 10:03 AM
badmatt's Avatar
badmatt badmatt is offline
Default Intercooler recomendations?
What size do you guys think would suffice a 1600HP set up... Id love to do air to air BUT the room under the hood is kind of limiting... And if i do. I have 23"x10"x4" max core size.. BUT If I move the radiator to the back of bed I can room for a full 27x14x5" intercooler But then there arises problems on keeping the motor it self cool... I dont see why the rear mounted rad would not work in a street car like a 31x19" 1.25" dual pass Rad with a pair of fans on it...
Can anybody shed some insight?
97 Sonoma "NERA": Pile O Sh*t. Literally.
Old 09-24-2008, 11:17 AM
camcojb camcojb is online now
call http://www.bellintercoolers.com for a recommendation, they will not steer you wrong as far as requirements for that power level. They custom build them at very reasonable prices also.
Old 09-24-2008, 01:42 PM
badmatt's Avatar
I explained my situation and basicly the space im limited too it would cause 5PSI pressure drop in the IC alone
Old 09-24-2008, 04:13 PM
hey, welcome to the club. That's the exact pressure drop I have............
Old 09-24-2008, 04:19 PM
BBC69Camaro's Avatar
I'm no forced induction guy, but I have seen a lot of builds mention Ron Davis intercoolers, maybe check them out?
http://www.rondavisradiators.com/
I have their radiator and its a work of art, so quality is top notch.
Old 09-24-2008, 10:21 PM
Blown353 Blown353 is offline
Gerhard Schruf at Bell Intercoolers is the man to talk to.
They do air-air and air-water.
How is the truck going to be used? If it's going to be a "quick blast then cool" type of thing I would run an air/water and put the heat exchanger & fans in the bed and leave the radiator up front. Size the heat exchanger & fan package correctly and it shouldn't heatsoak under prolonged use either.
1969 Chevelle
Old 09-25-2008, 06:06 PM
badmatt's Avatar
street driven Daily in the summer spring and fall... so air to air is a must for me...
Old 09-27-2008, 09:44 AM
FreddyG FreddyG is offline
Another vote for Corky Bell (and Gerhardt too)! They know their stuff!
Old 09-27-2008, 12:22 PM
OEM's use air-water on a lot of their combinations and they are tested & driven under any imaginable condition... think new ZR1 for a good example. It's air/water and I don't see GM putting "special use" conditions in the owners manual concerning the intercooling setup.
What I'm saying is that an air/water will work fine daily driven in any conditions provided you size the heat exchanger combo properly so it won't heatsoak under prolonged use.
Most air/water setups are very drag-race oriented and are only concerned about maintaining good IC temps for a few seconds, thus they're the air/water core, a tank for holding chilled water, and a pump-- that's it. Useless for the street. For longer periods of use you'll need a good pump, a properly sized heat exchanger (i.e. a radiator for the fluid in the intercooler system), a reservoir, and possibly fans depending on the location of the heat exchanger.
I helped on the design & build of a 900hp Procharged 427 SBF in a Mustang that's air-water. There was absolutely no room for a properly sized air/air core, so we had to go air/water. We used an air/water IC from Precision, an upgraded aluminum heat exchanger for a Cobra, a larger Canton reservoir, and a stock Bosch intercooler pump. The system doesn't heatsoak under extended driving conditions and works well, IAT's are usually 25F over ambient air.
Other than being a little heavier and more complex than an air/air setup there are no real disadvantages of a properly designed air/water setup. In fact, it gives you the option of adding chilled water or ice to the system if and when you go drag racing for a few more HP.
1969 Chevelle
Old 09-28-2008, 02:08 AM
deuce_454's Avatar
Default there is always room for an IC!
my money is on an air/water setup... you wont be driving at WOT with a 1600 hp car for many seconds at a time... and the water/air setup will soak the heat anddisappate it over time so the heat exchanger doesnt have to be able to cool it all at once but just have to coap with the average... and if you use an air/air intercooler core as your water cooler the extra volume will provide the system with plenty of capacity
and the water/air IC is small enough to be packaged anywhere...æ you couls even have two in the inner fenders....
here is an inspirational pic
Jake: Hit it.
