Old 09-03-2005, 07:20 AM
PaceCarNut PaceCarNut is offline
Default 1st Gen. Camaro Subframe modifacations?
I have a couple of stock 1969 camaro front subframes on the shelf here and since the coupes and the verts are the same, and im undecided of which body style to use, ( I will post that question with pics of the 2 canidates this weekend) But im going to start sand blasting and building the front subframe this weekend.
This is going to be a BBC set-up not sure about tranmission yet.
I will be installing DSE upper and lower a-arms with the aluminum coil overs, the steering box will stay in the stock location.
Are there any other modifacations that should be done to the front subframe? Like welding the seam on the frame from front to rear or someway to lighten/reinforce the frame without affecting its structurel support and strength?
Old 09-07-2005, 01:48 PM
squid squid is offline
Question
Anyone? I'm also curious. Thanks.
Old 10-13-2005, 12:07 AM
No one has an opinion?! No one else has re-done their subframe?
Old 10-13-2005, 05:45 AM
XcYZ's Avatar
XcYZ XcYZ is offline
This will give you a good idea what it takes to install the DSE coilover kit:
https://lateral-g.net/tech_articl...ilover_install
My LS7 69 Camaro
Old 10-13-2005, 07:01 AM
Scogin918 Scogin918 is offline
I've welded the seam from front to back, both sides.
Robert's 1969 Camaro - 2002 LS1/T56, 10 pt Chrome Moly Cage, HTH truck-arm rear suspension, Global West Stage III Front Suspension, Kook's Stainless Headers, Fikse Mach V's, 17" up front 18" out back, and still working on it
Old 10-13-2005, 07:07 AM
907rs's Avatar
907rs 907rs is offline
Yep, The seams on my sub will be fully welded as well.
Bill
