Old 10-16-2008, 11:37 AM
CraigMorrison's Avatar
CraigMorrison CraigMorrison is offline
If your goal is sub 4 sec 0-60, build an engine that makes around 600hp and the money you save on a TT SBC/BBC will need to go into a traction control or launch control system.
Art Morrison Ent.
www.artmorrison.com
Old 10-16-2008, 03:12 PM
That, or spend the extra money on relocating the motor to the rear over the axle so you can get traction!
Old 10-16-2008, 04:32 PM
rich-allen's Avatar
rich-allen rich-allen is offline
You got your answer from people that know from first hand experience yet you still have an opinion on weather their right or wrong.
Nelson motors run $35k - $65k..
67 RS/SS
Old 10-16-2008, 07:02 PM
hannes_slanec hannes_slanec is offline
I such a system that expensive?
Thanks Hannes
Old 10-26-2008, 05:09 PM
countryboy countryboy is offline
Default turbo knowledge
well as a true turbo guy (aka;nut), i have learned a thing or two about them.
First the main difference between a bbc and a sbc is displacement. which is everything with a turbo motor on the street. A bigger cid motor will replace the lost torque that is caused by turbo lag. Lag is the tendency to be doggy at rpms where you have little or no boost. now that doesn't mean you shouldn't run a small block, it means you should consider the cubes first. a larger engine (cid) will be easier to drive on the street and will be quicker off the line when not building boost first. Turbos can be very fun on the street and build power that hard to beat. Its possible to build very large small blocks these days. but building them isn't all that cheap when compared to a bbc of the same size.
Just some things to think on, hope this helps.
Old 10-27-2008, 03:36 AM
tyoneal's Avatar
tyoneal tyoneal is offline
Say, "LSx Turbo".
Project, "EnGULFed"
Ty O'Neal
"She Devil" aka. Betty
1969/70 Camaro SS
427 LS3, 600
Keisler Road and Track T-56
"Chester's '65"
1965 Buick Riviera
Old 10-28-2008, 01:45 AM
deuce_454's Avatar
im with countryboy on this... since its a streetcar id consider the offboost performance, (even nelson builds large smallblocks, 427 and 454 cui) where a v6 could deliver the same power at higher boost and rpm.. a larger dispacement engine is just much more driveable and pleasant on the street...
id go with the big block, especially if you have one allready.. and never mind the people going "you cant hook this or that" if you build a big block thats capable of 1500 hp, there is no law that states you cant leave the line at a reasonable rpm.. or limit boost in first gear...
Jake: Hit it.
Old 10-28-2008, 06:48 AM
Thanks Hannes
There are UK systems that offer launch and traction control for turbo engines that can be had for around $2500. Add in the wheel sensors and other misc electronics and you can probably have a complete system for about $3000-$3500.
Art Morrison Ent.
www.artmorrison.com
Old 10-29-2008, 07:07 AM
deuce_454's Avatar
if you are installing efi ect. anyway, id install an autronic.. it has all the above fearures, and i think dalhems is the sweedish dealer...
Jake: Hit it.
Old 10-29-2008, 04:23 PM
and
That is what I thought too, my plan was actually to go with around 9-9,5:1 and set the wastegate at low 6-9PSI only.
That way I have a efficient stop and go traffic behavior and a good off boost performance.
Aside of that I have been told that it is a fairytail that flow isnīt important for turbocharged engines, if so the BBC with my Dart 320 heads will flow much better than any SBC.
I further plan to run CNG (Natural Compressed Gas), it is enviroment friendly and got higher octane numbers.
Thanks so far for the comments
As for the hook, I really plan to do anything like well adjusted 4-link, everything heavy in the trunk like sound-system, battery, and even the radiator will come in the rear, under the trunk to transfer the weight.
As soon as I have money, I change to an alu block, I will first then buy the turbo setup.
