  #16
Old 10-28-2008, 01:45 AM
deuce_454's Avatar
im with countryboy on this... since its a streetcar id consider the offboost performance, (even nelson builds large smallblocks, 427 and 454 cui) where a v6 could deliver the same power at higher boost and rpm.. a larger dispacement engine is just much more driveable and pleasant on the street...
id go with the big block, especially if you have one allready.. and never mind the people going "you cant hook this or that" if you build a big block thats capable of 1500 hp, there is no law that states you cant leave the line at a reasonable rpm.. or limit boost in first gear...
Jake: Hit it.
