Old 10-13-2008, 08:12 PM
hannes_slanec hannes_slanec is offline
Cool 1000hp Sbc Vs 1000 Hp Bbc, Which One Would You Go With?
1000HP SBC VS 1000 HP BBC, WHICH WOULD YOU GO WITH?
Hello, currently I am about to build a 540cid standart deck BBC that soon is planed to run twin turbos.
My goal was around 3,5sec for 0-60 on the street with street radials and I was thinking 1000HP will be my need for that accerlation.
About the car
68 Impala SS427 clone
ca 1800kg
All heavy things are rear mounted at the backest possible point like bat, radiator (I saw that by the rally cars), soundsystem and so on
Car get a narrowd 9" for wider tires like 315 or even 345 and of course a posi differenzial.
I run Dart aluminum heads and want to go with a alu-engine too to lose some more weight on the front wheels
I also plan to go some inches back with the engine as far as possible.
4-link will be optimized
Now, I saw that Tom Nelson cranks 800HP out of a 427 SBC!!! and before I thought of course that guy know about hard valve springs, hottest cams and will go with race fuel to avoid detonation if he boosts the hell out of the block, but in one of the latest videos he stated that he got now a 427 SBC cranking out 1100HP Shocked
totally streetable on 91Okt on only 6 ****ing PSI which is the lowest performance on that engine
Seems like some more PSI and that engine is makeing 1500HP easily I think.
Of course I start wondering why the hell do I build a BBC for twice the money if a SBC is as strong as a BBC as well.
What is your members opinion about that competition, ok some of you will say the answer is, after the SBC is making 1100 now the stroker BBC will push out 1800-2000 but I think I will not get that much power on the streets, dont forget it is a street car and where I live we cannot drive Hoosier or M/T drag tires on the street.
Is there any speed/ or RPM range where it is a difference between 1000HP or 1500 or 1800HP when using the car on the street or will the HP always go out in nothing else than tire smoke?
Is there any benefit in the comparism between 1000HP SBC and 1000HP BBC, maybe the better low end torque would help by a car that is a bit heavier like my 1800kg Impala.
I have to say in that 69 Camaro 427 twin turbo video I realized that Tom always goes up to 4000RPM before he makes the kick down, maybe that would be different with a BBC
A crazy detai is that since new more and more mebers boost Big Blocks, I read every day things like 454TT, 502TT, 509 TT, 540 TT so a lot of people want to go that way now but maybe the most of them are drag racers and do not use ther cars on the street (maybe) but like that some fellas do the same now.
Tell me what you think, maybe I change to an SBC although I am proud of my stroker BBC
Thanks Hannes
Old 10-13-2008, 08:26 PM
TwinSting's Avatar
TwinSting TwinSting is offline
I vote small block. it is lighter and if it is one of Toms motors you cant go wrong. My 434SBC from Nelson made over 1500hp!! with about 1300lbs/trq
Old 10-13-2008, 08:37 PM
fesler's Avatar
fesler fesler is offline
I would go twin turbo small block but if you want tourque BB is the way to go, the small block will never do the same as the BB we have the built 572 in our Camaro and its a killer in tourque. The SB is quick the big block just kicks you in
Chris Fesler
Fesler Built - Scottsdale, AZ
Thanks for your opinion
Letīs go a bit deeper into it:
What static compression
How much boost
1500HP on what kind of fuel
How wild was the cam, valve springs and so on
Would you see a problem using that engine on the street for years
Thanks Hannes
Old 10-13-2008, 09:00 PM
Thanks for your answer too,
so a car that is a bit heavier would benefit from the BBC with Turbos, right?
With a big block it may be unnessery to wait for 4.000 rpm to kick down the gas padel.
That means 1000HP and 1000HP is not automatically the same performance?
Thanks so far guys
Old 10-13-2008, 11:23 PM
sacarguy sacarguy is offline
Default k
i just don't know where to begin.
first your NOT going to put a honest 1000 horsepower down on radials on the street maybee from a 50 mph roll but not 0-60
and yes i can speak from experiance since my race car ran mid sevens on radials.
yes nelson can do it easy if you want to spend a metric ton of money but there are plenty of others out there who can do the same thing for far less imo.
my radial cars motor put out 2600 horsepower and 2000 torque from a 434 cube small block ford with street style heads .. no yates heads or anything crazy and a single turbo. < 114 mm >
any engine shop can build you a 430 + cube motor with good heads and proper cam and then do a custom turbo kit with a 88 mm large frame turbo or a pair of t-67's and at 8-12 psi on pump gas you will easily hit 1k horsepower its not rocket science realy .. i build em all day like this.
Old 10-14-2008, 06:43 PM
Originally Posted by sacarguy View Post
1st,
Means, the high horses will be to feel when it comes from 60-120mph or something like that?
Old 10-14-2008, 08:15 PM
means you cannot hook 1000 hp with street radials, so the 3.6 second 0-60 will be extremely tough to do. However, from a roll 1000 hp is like a freight train, and very little can match the acceleration.
Old 10-15-2008, 07:08 AM
californiacuda californiacuda is offline
The 4 link, if its a parallel, won't make a difference on the street and the ride would be way too uncomfortable and harsh. Torque is what makes the car accelerate quickly. If you used some kind of positive displacent supercharger like a, roots, Kenne bell, Whipple, Magnuson that develop max torque at 2500 rpm, your max hp figure would probably not neeed to be more than 500-600 hp before your tires would blow off(depending on gearing, transmission, tire height, etc) up to 80=90 mph. My 2 cents.
Old 10-15-2008, 08:17 AM
I dont need any more low end punch since traction is a problem anyway, that is why I want to go with boost from the midrange when I have grip again.
500-600HP would make my 540 as N/A.
The 4-link will make a big difference, the angle of the trailing arms to the street and to one another is everything, I have a lot of literature about that issue and will keep the advises
But lets come back to the topic, what benefits if I use a BBC over a SBC with the same performance?
Thanks Hannes
