Originally Posted by camcojb
I don't think you can use the Pro Flo on a forced induction. It won't run a 2 bar or 3 bar map sensor, so you have no tuning under boost.
The engine would physically run with the current parts and easily meet you HP goals, but the compression and cam are obviously not ideal. Cool project though.
I talked to the guys at Edelbrock. They have since re-vamped and now use the system on a fully programable computer. The bad news is that it does not appear mine is compatable to upgrade. I can always sell mine and offset the cost of another EFI system, or use the base hardware and upgrade the harness and sensors to a different system. Looks like this will be a challenge (to keep the expense reasonable).
On the turbo side however, what are you thoughts on the type of turbos I need and how I go about selecting them?
