Old 07-16-2009, 07:30 PM
akrapovic's Avatar
akrapovic akrapovic is offline
Default ATS Wheel stud question
What ARP bolt are those of you with ATS spindles using? My application is a 69' camaro.
Thanks in advance
Old 07-16-2009, 08:05 PM
If your talking about the wheel stud, the upgraded bolt on mine is a 1/2 20 thread 3 inches long.
Old 07-17-2009, 07:32 AM
Blake Foster's Avatar
i beleave you would use the Corvette replacements
Blake Foster
www.speedtechperformance.com
Old 07-17-2009, 07:35 AM
The knurl is around .505-.509. Make sure to measure it though....that is what I needed in my C6 spindles.
Old 07-17-2009, 04:25 PM
akrapovic's Avatar
http://www.summitracing.com/parts/ARP-100-7708/
Think I found them. Thanks for the info guys!
Old 07-17-2009, 09:34 PM
chicane's Avatar
chicane chicane is offline
The stud used is ARP part number: 100-7703.
This peticular stud uses a 0.625" knurl which means that the existing holes have to be machined, NOT drilled... to accept the 0.625" knurl and maintain the proper "interfearance" fit required.
If you were to receive your hubs and/or spindles with the stock fasteners and wanted to upgrade... the 100-7708 will work with minimal work.
However, the 0.625" knurl offers some mechanical advantages over that of any other stud that can be used after market... next to that of the 5/8ths fine thread studs... 300 series part number appications... which is what I use for my personal bearing packs.
Old 07-23-2009, 05:08 PM
sik68's Avatar
sik68 sik68 is offline
ARP 7708's for me:
Steven
1968 Camaro: "TRACKDAY"
Build In Progress: https://lateral-g.net/forums/showthread.php4?t=10706
