Old 09-14-2009, 11:34 AM
hulsund hulsund is offline
Default baer brakes on detroit speed subframe
hello have an problem with brakes on dse subframe on an 1969 camaro
The parts i have is baer eradispeed number 2301011 -13" FRONT
Caliper is baer pbr no 4261444 is from an sport system i think
the problem is the caliper bracket is to small and dont fit to the holes in the spindel. have someone any ideeas about that problem.
is it possible to change the caliper bracket so the caliper i have can fit
Old 09-14-2009, 12:01 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Have you tried contact DSE? They would be more than willing to help you out I bet. They have great customer service.
GOOD LUCK!
Old 09-14-2009, 12:37 PM
Originally Posted by hulsund View Post
hello have an problem with9 brakes on dse subframe on an 1969 camaro
Those seems to be C4 Corvette brakes(1988-1996) DSE front spindle takes Corvette C5-C6 brakes (1997 and up)
63 Z06
Old 09-14-2009, 01:58 PM
Apogee Apogee is offline
It looks like you have the Baer "Track" kit which is based on the 1988-1996 C4Corvette calipers (2 holes in the face of the caliper) and the 13" x 1.1" HD C4 rotor. If you want to stick with Baer products, you should be looking at the Baer "GT" kits which is essentially just a C5/C6 2-piston caliper setup. Any 1997 or newer C5/C6 setup is a direct bolt-on.
Tobin
KORE3
www.kore3.com
Old 09-14-2009, 04:42 PM
Default brakes on dse subframe
hello can i use this one or ?http://cgi.ebay.com/ebaymotors/Brake...=p4506.c0.m245
Old 09-14-2009, 07:58 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Yes, C6ZO6 calipers have the same mounting pattern/offset as the C5 and C6 calipers.
That ad is only for the calipers, you will also need the C6ZO6 rotors (or aftermarket replacement). I'm sure you knew that, just throwing that out there.
My LS7 69 Camaro
Old 09-15-2009, 10:50 AM
Word of advice..Call Tobin at KORE3 and get all the right parts at one place. From correct mounting bolts to hoses. Its worth it.
63 Z06
