Old 09-19-2009, 03:28 PM
camcojb camcojb is online now
Default Just installed Musclerodz new ps and radiator reservoirs
Thanks to Mike for sending me a pair off his first batch of black anodized ps and radiator overflow reservoirs. I have hydroboost on my car and the integral reservoir didn't have enough volume to work well; to get enough fluid in the reservoir to stop groaning it would puke some out of the cap when hot. I then went to a remote reservoir AFCO can, but with the two bypass lines feeding into it the fluid would bounce off the cap at any level and leak from the gasket.
Mike has a new reservoir that could be used on any ps unit that uses a remote reservoir, but is ideal for hydroboost setups too. It already has two return lines that are fully baffled inside the unit so the retuning oil stays under the fluid level, reducing foaming, and doesn't splash up against the cap. He offers a matching black anodized radiator overflow, so I figured I'd get a matching set.
Install was very easy, even though I'm really limited on room with the twin turbo setup and all the extra plumbing. The black anodized version (he also offers standard aluminum) is very subtle and basically disappears in my engine compartment, which is exactly what I wanted. These are pre-production models and he may be tweaking the final version, but these looked and worked great for me. Here's a couple pics of the units along with the billet clamps he supplies for mounting. First the mounts:
PS reservoir baffles and mounting:
And the inside of the radiator overflow tank:
Old 09-19-2009, 04:08 PM
BlackenedRR's Avatar
BlackenedRR BlackenedRR is offline
Looks sweet!!!
Old 09-19-2009, 06:11 PM
Wow very nice piece. And nice write-up Jody.
Old 09-19-2009, 06:29 PM
67ragtp 67ragtp is offline
Jody - do you run a #8 line to the feed side(low pressure) of the power steering pump. Does most of the type2 and 3 PS pumps pull fluid from a distance with out problems. I mean can you mount these resivoirs on the radiator core support and run a couple feet of hose?
On my stock corvette accessory system the stock resivoir is just bove the pump and the feed hose is pretty big in diameter, this made me curious about how well the pump pulls from the resivoir. I would really like to get rid of the little plastic tank, would I be able to use these as well, I too will be running hyrdoboost? Your thoughts, BTW they look real nice- Thanks Rich
Old 09-19-2009, 06:44 PM
awr68's Avatar
awr68 awr68 is offline
Looks really nice! Great work Mike!! This should make for a very complete and great working system!
Tony
'68 Camaro
Old 09-19-2009, 07:03 PM
I run #10 (this is what this reservoir is set up with also), no issues at all with the distance from the reservoir to the pump. Try to keep the reservoir higher than the pump (mine is just above pump inlet level) and works great.
Old 09-19-2009, 07:11 PM
Thanks Jody- appreciate the info.
Rich
Old 09-19-2009, 07:32 PM
9deuce9rr's Avatar
9deuce9rr 9deuce9rr is offline
those look great man! like that they're black and not polished... looks meaner!
My Flickr
1966 Chevelle 300 - SBC 350 - Rushforth Concepts - Mercedes Iridium Silver Paint - Air Ride Technologies - F/R Big Brake Kit
Old 09-19-2009, 08:29 PM
That looks great Jody, They have some nice stuff.
Old 09-19-2009, 10:43 PM
Blown353 Blown353 is offline
I'm going to need a set of those myself...
How is venting taken care of-- is there a small baffled hole in the caps somewhere?
1969 Chevelle
