Old 03-15-2010, 08:09 PM
phillym5 phillym5 is offline
Default Speedtech sub frame... installation was easy!!
I received my Speed Tech sub frame a few days ago... along with the high clearance control arms... Coil overs... ect. Nice piece.
I sent it out to get powder coated.. and spent a few hours putting it together on the jack stands. It came with EASY install instructions for each piece needing to be installed.
Once i had it all together... i went over and pulled the motor out of the Camaro... brought it over to the sub frame and dry fitted it. It was a thing of beauty. The motor is a 408 LS. EVERYTHING is custom. All the oil plumbing for the turbo's fit...power stearing lines fit... pretty much everything.
Only issues we had were the trans on my car(based on the angle we had it set) was a bit lower than the mount provided. But i just made some steal spacers to put in between the trans mount on the frame... and the cross member.. done. Then the motor was set back a bit on the stock frame. So we had to make some custom motor mounts. Only took Brian a couple hours to do.
Here is some photo's from the last two days. Tomorrow im going to put the majority of the car back together.. Brian is going to run the brake lines and change one of the dump tubes... and i am going to be finishing the plumbing and putting the front end back on. Should be done in a matter of days.
It is amazing how easy the frame swap is. If we didn't have a ridiculous motor in that thing.. we could have done the entire swap in 2 days. But instead... it will be 4.
One more thing... im really impressed with the amount of room there is at steering lock. Im running a 8.5 inch front wheel.. and there is room for at least a 10. Tons of room left for future upgrades.
Old 03-15-2010, 08:59 PM
nvr2fst nvr2fst is offline
You got this one going off quick, Sweet.
I spoke to a couple of the guys you mentioned from our pms. thanks for the heads up.
Old 03-15-2010, 09:26 PM
You made some nice progress. Thats a sweet looking engine.
Old 03-15-2010, 09:38 PM
scherp69's Avatar
scherp69 scherp69 is offline
Looking good!! I know the feeling about having so much extra room. I have 245's with a 8" rim and tons of room to spare.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 03-15-2010, 09:39 PM
Josh --
Looks good buddy!
Hey! I called Blake... he said they wrote those instructions just for you!
Glad to see you're making good progress!
Old 03-15-2010, 10:27 PM
youthpastor's Avatar
looks awesome- lots of space-
[SIGPIC][/SIGPIC]
CHRIS HOLSTROM CONCEPTS
http://chrisholstromconcepts.com/
Old 03-16-2010, 02:49 AM
Sweet man. Now get that ride back on the road and make some more bad ass vids!
Old 03-16-2010, 05:54 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Nice!
My LS7 69 Camaro
Old 03-16-2010, 08:14 AM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Very cool Josh. Keep us posted on this build please.
Old 03-16-2010, 09:13 AM
monza's Avatar
monza monza is offline
You proved me wrong on the time frame for the install!
Nice one, now stop rolling on those skinny pro-street front tires it's like roller blade style..
Dave
FUeL 69 Camaro RS
68 Corvair coupe
65 Impala SS
65 Corvair convert
64 Corvair Rampside
62 Corvair Greenbrier
http://www.sourceboards.com/
