Old 12-20-2005, 05:40 PM
hotroddr hotroddr is offline
Default Radiator angle
Anyone see any problems with this angle? I am mocking up the radiator so I can finish the frame and I think It should work best to scoop some air up from under the bumper with an air dam, as well as some from the grill, then pull it through the radiator and vent it to the wheel wells. This angle seemed the most logical to me for air flow but I wanted to run it by you all.
It now sits real low in the engine compartment, which seems like it could be an advantage for aesthetics and whatnot.
I dont like the look of an air dam under the bumper right on the front of the truck so I was thought I may as well use some of the air that would otherwise go under the truck by scooping it up with a set back air dam, kind of like the c5 corvette(actually 3 and 6 too probably)
68 firebird
66 Suburban
Dmax GMC
Old 12-21-2005, 06:35 AM
XcYZ's Avatar
XcYZ XcYZ is offline
It shouldn't be a problem as long as the airflow is good. You see some unique radiator placements in the racing world, and if it works for them...
My LS7 69 Camaro
Old 12-21-2005, 12:48 PM
TwinSting's Avatar
TwinSting TwinSting is offline
The radiator and intercoolers on my Vette are at almost that angle. It works great!
Shaun
Old 12-21-2005, 01:12 PM
XcYZ's Avatar
Shaun, I think we need some pictures of that beast.
My LS7 69 Camaro
Old 12-21-2005, 02:19 PM
Autokraft's Avatar
Autokraft Autokraft is offline
Supporting Vendor
Autokraft.org
Like Scott said, let's see some pic's of that awesome corvette.
Kurt
Old 12-21-2005, 11:12 PM
pictures pictures pictures......please?
68 firebird
66 Suburban
Dmax GMC
Old 12-21-2005, 11:21 PM
race-rodz race-rodz is offline
note: the angle is fine...however the filling point needs to be the highest point in the system to avoid air being trapped...and getting the coolant level "full".... an over flow recovery tank similar to a new car would work great.
Old 12-21-2005, 11:23 PM
note #2: make sure you have enough rad......... as i recall the factory duramax rad is "gihugic"
also...dont forget about the intercooler....... gonna need one of those too
Old 12-22-2005, 07:17 AM
syborg tt's Avatar
go here
https://lateral-g.net/forums/showthread.php4?t=2405
marty-mj
