Old 07-09-2010, 11:35 PM
Tom.A's Avatar
Tom.A Tom.A is offline
Default ATS Road Race Pan oil lines
Anybody with the ATS LSX pan know which oil line is the return for the remote filter? I looked on the ATS site but don't see anything. I honestly have no clue if it matters or not but I am close to turning the key after I put fluids in and don't want to take a chance.
Thanks,
Tom
Old 07-10-2010, 05:37 AM
dhutton dhutton is offline
Post no. 2:
http://www.pro-touring.com/forum/showthread.php?t=70180
Old 07-10-2010, 06:23 AM
clill's Avatar
clill clill is offline
It does matter especially if you have a oil filter that has a check valve. The ATS instructions at one time were wrong so make sure you get it right.
Old 07-10-2010, 07:04 AM
camcojb camcojb is online now
The front line is the engine out line, and the rear line with the 1/8" NPT fitting is the return into the engine. By looking at the pressure fitting you might think that was the out line, but it is not.
As Charley says, it does matter, especially if you have an anti-drainback filter..................
Old 07-10-2010, 09:31 AM
Moose Moose is offline
Thanks again jody for the help with mine. going to weld the a straight fitting on to the pan and send back out for powder coat!!
have it back in a few days!
Old 07-10-2010, 04:26 PM
Tom.A's Avatar
Thanks Guy's. I hope I got the later version but I don't know. I don't recall getting any instructions with pan.
=camcojb;295408
That is what we thought. Glad I asked. I am using the CV products and HP6 filter so I don't have a check valve.
Thanks Again
Tom
Old 07-11-2010, 07:11 AM
Tom,
did yours come with fittings welded to the pan? any chance I could get a pic of the top of the pan without a gasket?
Old 07-11-2010, 10:07 AM
Tom.A's Avatar
Originally Posted by Moose View Post
Tom,
Moose,
I looked all through my photos and I have no pics. Sorry. The fittings did come welded though.
Tom
Old 07-11-2010, 10:25 AM
Tom,
I've had a couple of their pans. The one I have now is the first one I got and it is not welded inside the pan where the tubing comes through the pan rail, only welded on the outside. The later one I had was welded inside and outside, plus had a brace outside to help support the rear tube/fitting.
Old 07-11-2010, 05:18 PM
Thanks Jody. you and abunch of others are why I love this site!
