Old 10-15-2010, 08:46 PM
70rs's Avatar
70rs 70rs is offline
Very cool project Greg. I can't wait to see it in person.
Eric
Old 10-16-2010, 04:27 AM
ProTouring442's Avatar
Originally Posted by kennyd View Post
stay away from the hilborn set-up go with the Inglese set up .they use a comon plenum under the base to equal the runner volume .
Thanks guys... but you're preaching to the choir -- I already run one of my cars with an Inglese intake (using Imagine Injection TB's).... and I totally "get" the plenum. I took my polished weber intake off (that used lines to a small common plenum for the MAP sensor) -- as soon as I could get my hands on the Inglese unit.
I would never use the Hilborn unit -- that was just Steve's description when I said "I'll run an 8 stack injection unit".
I am a bit confused on this. Why would the plenum be necessary? Wouldn't 8 individual throttles provide better throttle response? I ask because all of the factory cars I know of, Ferrari, my M5, etc that use individual throttles do not use a common plenum.
Thanks!
Shiny Side Up!
Bill
Never met a man with real talent who felt the need to deride the efforts of other.
Old 10-20-2010, 06:23 PM
Thanks!
Shiny Side Up!
Bill
Bill --- I have no idea buddy!
All I do know is that with the common plenum in the Inglese intake - I have plenty of vacuum for the items that need it. BTW -- Just so there's no confusion -- the plenum is not like a carb plenum -- there's no common area for the intake side -- just for creating a vacuum source. Otherwise each TB has it's own runner. Make sense?
Old 10-20-2010, 06:27 PM
My only "update" is that the rear end has been ordered from Kugel -- and the appropriate deposit sent to SAR... so work should be cranking up here shortly if not started already.
I was reading the threads on the "full floater" rear ends - ala Matt and Gonzo... and I was chuckling to myself. I'm not sure what those bad boys run - and I'm certain they're expensive - but a fully chromed out "show" rear end like the one I just ordered is an OMG! Worse - it won't improve handling one dang bit!
Oh well.... it's "hot rodding" right?!
Old 10-20-2010, 07:20 PM
96z28ss's Avatar
96z28ss 96z28ss is offline
I was there today at SAR for other things and your car is not being worked on, maybe in a couple weeks.
1969 Camaro LS2/T56 D1SC
www.automotivedesigneng.com
Old 10-20-2010, 08:12 PM
Yeah -- figured that - the rear end is a major component for what we're doing and it just now got ordered - and is 4 to 6 weeks out... no point in tearing the car apart quite yet.
Thanks for the update though!!
Old 10-20-2010, 08:54 PM
awr68's Avatar
awr68 awr68 is offline
Greg are you changing the ride height at all? I know tire size is being changed. Did you order the wheels yet? How bout the coffee holder?
Tony
'68 Camaro
Old 10-20-2010, 09:05 PM
Well -- good questions -- it's a highboy -- think there's a reason for that name... A low boy would have the body channeled over the frame giving a lower look.
Wheels are going to be 20's rear and 17's front. And we're doing 215/50/17s and 295/45/20's BFG KDAs is the thinking right now.
I wanted more rake - nose down... but that will have to be done with wheel/tire size selection since we don't have adjustments for coil over mounts etc. Actually on these style cars - you want the ass in the air - so you can see that extremely expensive rear end I just bought! LOL
My buddy Stans 32 sits lower and looks lower sitting next to mine in this photo. His car was a "great 8 Riddler" in 1994 and runs all torsion bar suspension front and back (pretty high tech stuff in '94). He's running an IRS as well, but I don't think I can get down there.
Old 10-20-2010, 09:28 PM
Steve won't let me put a coffee cup holder in... LOL
I wanted one built in a console type deal - but he said NO. So have to go with what the pros know. I'll just buy a plastic beanbag jobbie at Fred Meyer I guess... and then toss it in the trunk when not in use.
Old 10-20-2010, 09:42 PM
awr68's Avatar
I can't help it...I like them low like Stan's! Tell him hi for me!
Looks like the pic was taken at PIR?
Tony
'68 Camaro
