Old 11-12-2010, 09:13 PM
snappytravis's Avatar
snappytravis snappytravis is offline
Default Body Seams
So what about filling all the body seams like the rear panel, panel below back glass and fender to header panel? Just don't like the seams below back glass but I am still not sure about the rear tailight panel seams. pos some pics thanks
Old 11-12-2010, 11:35 PM
70TWO NOVA's Avatar
70TWO NOVA 70TWO NOVA is offline
My buddy did that on his 68 Firebird.....
Brian Miller
-1972 Nova
-1968 Camaro
-1967 C-10 step side 4x4
-2000 Dodge Dakota
it'll buff out........
Old 11-13-2010, 05:36 AM
Default seams
Thanks for the pics
Old 11-13-2010, 06:11 PM
speedshftr speedshftr is offline
i have a 68 camaro and have the front upper and lower fenders made into one i also have the front upper header panel and lower valance welded to fenders.i love the uniform look.ill try to add pictures
Old 11-22-2010, 12:18 AM
Firebird Kid's Avatar
Firebird Kid Firebird Kid is offline
i also filled in the back under-window seams. i just went over it with light coats of body filler over the factory seam sealer. is there a different way i shouldve done it? looking back i dont want it to crack and ruin the paint. how is your guys' holding up?
Old 11-28-2010, 04:39 AM
meenaggie meenaggie is offline
All of the camaros I have seen "fill" the seams with body filler crack over time. I am sure there are some better fillers out there with fiber reinforcement but if you want it to last you need to weld it. And before you weld it you need to get all of the factory seam sealer out of the joint (try a soda blaster or spot sand blaster).
Old 11-28-2010, 05:35 AM
my car was fully handstripped by me then everything was welded up before any filler went on.i know the do tend to crack though.hek that will give me a reason to tear it apart again/lolkidding
Old 11-30-2010, 04:42 PM
Jim Nilsen's Avatar
Jim Nilsen Jim Nilsen is offline
I filled my seams with seam sealer to make them flat as possible.
You can add extra sealer over the seam and let it setup for a week and then go back and trim it down flat to the surface or sculpt it in the corners of the tail panel and then epoxy over it. It can then be treated with primer and paint and will be good for as long as any seam sealer job would except it will look 10 x better. You do have to be able to let the car sit while it is shrinking down but I can't think of any car at that point that doesn't have a weeks worth of work to be before paint unless you wait to do the seems last.
When in the sun you can't see the seams on my car and it has to get really cool temp wise and be at the right angle to see the small amount of a seam shadow that shows.
You can also do the qtr to rear panel in the corners of the trunk lid area with the seam sealer the same way and it will be smooth and never crack.
I have had really good luck with this method and the seams could never be better looking or as invisible as they are.
May the Horsepower Be With You !!!!
Old 12-02-2010, 02:15 PM
aktmracer's Avatar
aktmracer aktmracer is offline
I just had this same discusion last week with a friend, I thought it would look good but was worried if it did'nt it's to late. Im just about at the point where I need to make a choice and after seeing those pics I think I'm going for it. Your cars look great. Anyone with a 60's chevelle filled in please post some pics...
Jeriah
http://s812.photobucket.com/albums/z...67%20Chevelle/
1967 Chevelle LS1/4L60E
1980 FJ40 LT1/TH400 waiting to go in
Old 12-02-2010, 06:20 PM
elitecustombody's Avatar
If you're going to smooth the seams, weld them,but if you don't mind seeing the ghost lines of the seams or worse ,cracks ,then you can use filler or seam sealer.
my .02 cents
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
