Old 07-09-2011, 10:53 AM
70rs's Avatar
70rs 70rs is offline
Yeah, I get it. Mine look like crappy welded lumps. Haha! With a bit of practice I should do ok.
Another option is the weather pack connections. More$$ but water proof and easy to remove if ever needed to. Tough to hide those though. Pretty bulky.
Eric
Old 07-11-2011, 05:39 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Great updates. Nice looking gauges. Keep up the great work.
Old 07-11-2011, 09:52 PM
68400BIRD 68400BIRD is offline
Thanks.
Just finished detailing my rear tail light lenses.
Some before and after pictures.
Here is what I started with.
Buffed out the lenses.
Housings before powdercoating.
After powdercoating.
Lenses all cleaned up and painted black again.
Lenses inside housings.
Old 07-12-2011, 03:22 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
Wow - those lamps look excellent!!!!!!!!!!!!!!!!
Old 07-18-2011, 04:17 AM
69MyWay's Avatar
By the way....
One those brake lights, make sure the inside lip of the light socket hole is clean and free from paint as well as the back side (at least one) of where the mounting bolts/nuts go to the rear body panel.
The light socket doesn't have its own ground - it has to ground through the lamp housing.
Just got our lamps all in over this last week and found that out...the hard way.
Old 07-18-2011, 09:37 AM
Those look great, you did an excelent job.
Old 07-18-2011, 10:01 AM
Originally Posted by 69MyWay View Post
By the way....
Thanks for the advice. I'm already in the process of adding grounds to all of the tail light sockets. I'm not a fan of how they ground in the first place. Then add in that every square inch of my trunk now has several coats of spatter paint along with clear and my tail light housings are powder coated, will make for a bad ground for sure. The tail light sockets have a small hole that I can fit a wire down and solder to the grounding clip.
Old 07-18-2011, 10:02 AM
Thanks Wayne!!!!
Old 07-18-2011, 11:14 AM
70rs's Avatar
Killer job on those lights! Want to restore mine?
Eric
Old 07-18-2011, 11:16 AM
Send them over I have more time than money
