Old 09-16-2012, 07:31 AM
Sieg's Avatar
Sieg Sieg is offline
The AED Performance fuel supply arrived so I fabbed a carb stand and put the Ultra HP on the bench to verify calibration. I hope this carb is as good as I've heard. Personal opinion - I love the design upgrades and look!
Mains - 70
Power valve - 6.5
Idle bleeds - 70
Main bleeds - 45
Pump shooters - 31
Pump cams - Pink 1st position
Fuel screws were random now set at 1.5 out.
Idle air bypass - 3 turns out
Old 09-16-2012, 07:39 AM
intocarss's Avatar
That is sexy
Old 09-16-2012, 03:50 PM
Roberts68 Roberts68 is offline
That is sexy
X2. I concur. Carb envy has reached the Midwest.
Old 09-16-2012, 06:50 PM
coolwelder62's Avatar
That is sexy
What he said.That black carb is awesome.
Old 09-16-2012, 07:02 PM
That looks killer dude! Love that color... I did read it chips easily somewhere. Hopefully it holds up.
Old 09-16-2012, 08:35 PM
AWESOME! Love that look!
Sure hope it works for you as it should and maybe even better!
Old 09-16-2012, 09:24 PM
Sieg's Avatar
Thanks guys
Dave - I don't think it's the most durable finish I've seen, not as sensitive as anodized aluminum though.
Greg - Hopefully the head and carb make up for my inferior rebuilt flat tappet cam.
One issue that came up when they tore the motor down is they didn't notice the gear drive was a variable advance so they don't know position it was set at. That bothers me.......more than a little.
I believe -2* / 0* / +2* are the options for my drive.
http://static.summitracing.com/globa...jj-350-91c.pdf
Anyone have an educated guess?
Here's Edlebrock's specs which say 0* for "most" applications.
• CAMSHAFT: Torker-Plus Hydraulic
• CATALOG #5002
• ENGINE: Chevrolet 265-400 c.i.d. V8
• RPM RANGE: 1500-6500
• CAUTION: Do not use dual valve springs.
Use only recommended Edelbrock Sure Seat
Valve Springs #5703.
Use stock ratio rocker arms only.
Duration at .006" Lift: Intake 292° Exhaust 300°
Duration at .050" Lift: Intake 232° Exhaust 234°
Lift at cam: Intake .325" Exhaust .325"
Lift at valve: Intake .488" Exhaust .488"
Timing at .050 Lift:
Open Close
Intake 10° BTDC 42° ABDC
Exhaust 47° BBDC 7° ATDC
Intake Centerline: 106° Lobe Separation: 108°
• CAUTION: Use Edelbrock Performer-Link Timing Chain and Gear
Set #7800 or Accu-Drive gear drive #7890. Do not use late
model timing chain and gear sets that are designed for emission-
controlled engines. These timing sets are machined in a
retarded position and are not recommended for this camshaft
installation. Edelbrock Timing Sets feature three keyways for
specified timing selection. Use "0" position for most applications.
Edelbrock's drive is 4* at cam and 2* at crank.
Old 09-19-2012, 10:04 PM
Sieg's Avatar
Edelbrock tech said the Comp Cam dual springs I had with 121 lb seat and 343 lb. open pressure were within there acceptable range with the cam.
Lucas 30W break in oil and Joe Gibb's mil-spec 10/30W oil on order.
Doug's 368 headers arrived, fingers crossed that they fit! The overall quality (especially ceramic coating) is much higher that the Hooker Comp's I received earlier.
Quick Fuel throttle return spring bracket test fit and appears to be a well engineered "no frills" system.
Motor should be back together this week or first of next week. With a little luck Norwood will be back on the road in a couple weeks.
Old 09-23-2012, 09:52 PM
Sieg's Avatar
More progress on the "practice" frame
Thankfully it goes under the car.
Old 09-23-2012, 09:58 PM
Go back and fill in the low spots with some rose welding.... grind 'em down...
It'll look beautiful! And it's good practice.
