Old 02-04-2013, 05:29 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
hey Gav I am not real good on computers but I have a build thread on projects, just type in New Build,another 1969 camaro I dont know how to copy a link for you but check out the pics and I will help in anyway,I did anther recently for a friend and used same measurements and it worked fine on it too.
Old 02-04-2013, 05:33 PM
Originally Posted by usa-69z View Post
Ryan , i thought you would narrow the diff and then order rims to suit with the right backspace? also is that measurement from the diff flange to flange or wheel mounting pad ?
Im confused on how to go about this,, what comes first the chicken or the egg?
That would depend on your build. If you are building a rear end anyways, choose your wheel first with your dish preference and start fitting. It's best to measure your car because from experience no two cars are alike.
Old 02-04-2013, 09:53 PM
Todd in vancouver's Avatar
Todd in vancouver Todd in vancouver is offline
Being new to the PT build I'm presume there are many ways to get the results each person is after. My understanding and the way I planned my build was to do the mini tub while I was replacing quarter panels, assemble an install my rear suspension set up, then measure and order the rim & tire combination to fill the big hole I just created. Is that not why I'm going to have to order a set of these super expensive PT type wheels I keep seeing on these builds?
Todd in Vancouver, Canada
'67 Camaro SS
How hard can it be?
Project Obsession
https://lateral-g.net/forums/showthread.php4?t=40384
Old 02-04-2013, 10:30 PM
usa-69z usa-69z is offline
, so how do i work out my dish or backspace without a diff to measure from? Im after maximum dish i can run..with a 12 inch rim.
I had a measure of my diff today ,, its a tru trac moser ,, it has big drums,, did they use ford rear brakes on some of these? Im sure i saw a ford logo stamped into the backing plate somewhere when i purchased it? will that be a factor with getting rear discs or are the axle flanges the same stud pattern?
sorry i got a lot of questions here ,, i also thought narrowing each side 2.5 would bring the saddles very close to the axle flange..
Gav
69 CAMARO - RIGHT HAND DRIVE AUSSIE MODEL.
383 SBC 8 STACK INJECTED EFI.
RIDETECH FOUR LINK REAR - DSE MINI TUBS .
SPEEDTECH FRONT A ARMS & COILOVERS.
MOSER 3.7 REAR- 6 SPEED T56 TREMEC.
FIKSE RIMS ETC ETC..
Old 02-06-2013, 10:31 AM
Gav
If you want to simplify things, have moser weld on Chevy housing ends on. Pn 7900 or 7900FM (flush mount). This will allow you to use your parking brake backing plate as a bearing retainer depending on the disc brakes you run. The 7900 uses a large press on ford style bearing so that eliminates the c clip. If you already have your rear end and need to narrow it, you can cut off the ends and replace with the 7900's. You can get your axles cut and resplined and change the bolt pattern to Chevy 5x 4 3/4.
Old 02-07-2013, 08:14 PM
v8s only's Avatar
v8s only v8s only is offline
my 69 camaro has 55 inch rear end wheel mounting surface to wheel mounting surface that's 5 inches shorter then stock wheels are 18x12 5.5 back spacing fits perfect in my car
Tony
68 Camaro pro touring sold
69 Camaro pro touring for sale
62 corvette pro touring sold at barrett jackson
Old 02-08-2013, 03:40 AM
Vince , i do already have a chev pattern tru trac Moser rear,, but im thinkin i have ford big brakes as it got the torino bearings ? I just thought the flange pattern maybe different to a stock chev flange pattern, ill have to measure it..THe spring pad mount on the diff would be very close if i narrowed it to 55 inches.. do they end up being that close to the disc and bracketry?
Gav
Old 02-08-2013, 03:41 AM
Thanx Tony ,, that seems to be the average combo for the mini tub im finding..
Gav
Old 02-09-2013, 12:27 AM
Gav
yes, you would have to move the leafs in too.
Old 02-28-2013, 07:52 PM
Stovebolter's Avatar
Stovebolter Stovebolter is offline
Tony,
So a 1969 Camaro stock hub to hub is 60"? I was told the Z28 is 58"? Are they different for different X codes? Just asking.
Gav,
As Vince suggested, brakes also may play a role. I'll probably go with the stock width rear and stock dish making replacement a cinch. I'm going with Moser full floater (steel hubs) and PBRs on Willwood GT rotors. GMR makes the mounts for the PBRs and a sweet little parking prake optiion. At 58" as a standard width it will be easier to get a replacement if needed. I'm sure Moser can and will make any width but they have specific widths already in stock. And from what I see they have good prices. Are you dead set on keeping the 12 bolt? Just a thought.
David
David
