Old 02-18-2013, 04:43 AM
Jay Hilliard's Avatar
Scott...subframe looks great. Kevin...awesome job on the welding. What is the tab in front of the A-arm bracket used for?
Jay
Old 02-18-2013, 05:24 AM
coolwelder62's Avatar
Originally Posted by Jay Hilliard View Post
Scott...subframe looks great. Kevin...awesome job on the welding. What is the tabe in front of the A-arm bracket used for?
Jay,The tab is for Kevin's lower baybar mounting point.
Old 02-18-2013, 05:52 AM
Sieg's Avatar
Sieg Sieg is offline
Originally Posted by coolwelder62 View Post
Kevin is prob, a little steadier w/mig gun these day's. He's 22 year's younger than I am.
Exceptional welds! What welder was that little rug-rat using?
Old 02-18-2013, 07:10 AM
This is a good looking frame. Kinda glad I've still got the OEM sub since I have more options by waiting. The punch/flare would go great with the look I'm after.
Couple questions...
1. Is the hub-to-hub dimension of this setup the same as OEM? Trying to understand what, if anything, is to be considered when it comes to wheel/tire fitment. A little narrower than my current setup would be added benefit with my setup.
2. Will there be tabs front and rear of the LCA mounting locations to put them in double-shear?
John
'71 Nova (Build thread)
FFR Roadster
Old 02-18-2013, 08:46 AM
Miller Matic 252 /.035 wire,75/25gas.
Couple questions...
Hub face w/o rotors is 60.5.The LCA will be in double shear.The rear lower brackets are finished just not in the photo.We are still working the frt bracket to hold the LCA and the rack & pinion bolts also in double shear. In a few days Kevin should have frame all finished up and assembled for everyone too see the final product.
Old 02-21-2013, 07:56 PM
Well gang Kevin is all but finished with the fab workon his sub frame of the new design.A few lighting holes to drill then off too the powder coater
Old 02-21-2013, 08:16 PM
I think the new design turn out great.Kevin did an awesome job.It ended up being a few pound's lighter,a whole lot stiffer,And look's Outstanding.and working on it togather was fun.Now it's time to start working on that alum unit.
Old 02-21-2013, 09:49 PM
Jtomas801's Avatar
Jtomas801 Jtomas801 is offline
The new subframe looks great! You and Kevin do awesome work.
Thanks,
Jon
_______________________________________________
Jonathan Feltis
69 AMC Javelin - Back in Progress.
Old 02-21-2013, 09:57 PM
Bryce Bryce is offline
great work as usual.
Old 02-22-2013, 02:19 AM
Jgpclone's Avatar
Jgpclone Jgpclone is offline
man ur work is top notch i am speachless
Hi my names is danny and im a "hp junky"
2006 tbss stock dd
1969 camaro project
2004 scsb silverado joe gibbs clone
