Old 01-20-2013, 03:42 PM
coolwelder62's Avatar
Default Scott Mock/vrp New 2013 Sub Frame Design
As the heading say's I have have a new sub frame Design to 2013.This will be an upgrade for those of you wanting an even more Professional Looking Design.I have Added new Mandrel bent 2x4 mail rail's,CNC Plasma cut flat part's,New stronger cross member design,A new upper A-Arm mounting plate W/more coil over shock ajustment.A New sway bar mounting tube design,All new lower A-Arm surport mount's,New frt. body bushing mount bracket's w/alinement hole's,Punched & dimple die'd lighting hole thur-out the design.An all motor mount & new tran's crossmember design.All material will be P/O tubing or plate.This is mandrel bent rail frame only.
Old 01-20-2013, 04:16 PM
Bryce Bryce is offline
where are the pictures
Old 01-20-2013, 04:46 PM
Sorry It took for ever for photobucket too work.
Old 01-20-2013, 04:56 PM
Understand We still have a ton of work left too finish it out.This one will be going under My son's Kevin's Camaro.He is doing a lot of the work on this first one.It look's like this one wil be about 10# lighter & alot stronger than my Org.design.It should look as nice as the best sub frame's on the Market.
Old 01-20-2013, 05:14 PM
eric1967 eric1967 is offline
Looks really good
Old 01-20-2013, 06:15 PM
MODO Innovations's Avatar
That looks really good Scott. Can't wait see what's next.
Shannon
Modo Innovations
940-391-9002
Old 01-20-2013, 06:36 PM
Sieg's Avatar
Sieg Sieg is offline
Good On Ya Scotty!
And thanks for the tease...............
Old 01-20-2013, 07:36 PM
Jay Hilliard's Avatar
Very nice. Really liking the look. Curious to see how sway bar mounts. What rack and pinion are u using?
Jay
Old 01-20-2013, 07:52 PM
The sway bar mounting tube is not finished yet.About 2 more week's and it should be all finished up.Rebuilt ford rack or New AGR unit's.
Old 01-21-2013, 08:45 AM
73camarols1 73camarols1 is offline
Default DSE Rack
Congrats. The new frame design looks awsome. Is there a way to run DSE rack on your original frame design? Thanks Bill
